Calendar and Contacts Issue
Mazate
Beginner
ownCloud version: 8.1.1
Webserver: Apache
OS: Linux Hosting Package
Postby Mazate » Thu Aug 20, 2015 4:56 am
I realize that this is already a known issue and has been discussed but through my searching around I'm not able to find a workaround for it. I just did a clean install of owncloud and when going to enable the calendar and contacts apps I'm getting this error: URL error 60: See http://curl.haxx.se/libcurl/c/libcurl-errors.html
Is this something that will be fixed in 8.1.2 or is it an issue with my hosting provider's version of something on the server? Do I need to wait for 8.1.2 on September 1st or do I have to request that something get updated on the server?
Any help is most appreciated.
David
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Calendar and Contacts Issue
Postby RealRancor » Thu Aug 20, 2015 10:32 am
have a look at viewtopic.php?f=17&t=29790 for some pointers.
*gone*
Mazate
Beginner
Webserver: Apache
Postby Mazate » Thu Aug 20, 2015 10:24 pm
Is this an owncloud software problem or is it an issue on my hosting server? If it's an owncloud problem is there any sort of reasonable likelihood that it will be resolved in 8.1.2?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Aug 20, 2015 10:37 pm
please see the linked FAQ to see if this is a configuration problem or a problem of outdated libraries on your webhoster.
As this is mostly not an issue with oC there is very likely nothing to fix in 8.1.2
*gone*
Mazate
Beginner
Webserver: Apache
Postby Mazate » Fri Aug 28, 2015 1:07 am
Ok, I have since changed hosting providers. I'm not using a new hosting provider and this is the error I'm getting now when trying to Setup the calendar or contacts application:
cURL error 60: SSL certificate problem: unable to get local issuer certificate
I got this error before and after I installed the SSL on cpanel.
Any help is appreciated.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Aug 28, 2015 8:56 am
RealRancor wrote:have a look at viewtopic.php?f=17&t=29790 for some pointers.
*gone*
Mazate
Beginner
Webserver: Apache
Postby Mazate » Mon Aug 31, 2015 12:45 am
Finally found the solution on this. Downloading the apps from the owncloud website and then inserting them into the apps folder made it so that I could successfully install both apps. I see after a lot of looking around that many people have had this issue. I hope this can help someone else if you happen along this thread.
