Secondary Directory
HPCplc
Starter
ownCloud version: 8.0.2
Webserver: Apache
PHP version: 5.6.7
Secondary Directory
Postby HPCplc » Tue Aug 25, 2015 12:39 pm
We are currently running owncloud for a specific set of users. We now have a different set of users who need access to a seperate directory - is this possible through owncloud or would we need to set it up in the current directory and make sure permissions are only set for the users who need access?
Hope this makes sense
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Secondary Directory
Postby RealRancor » Tue Aug 25, 2015 11:22 pm
there is only one main datadirectory in ownCloud so either setup a second oC installation or use groups.
*gone*
HPCplc
Starter
Webserver: Apache
PHP version: 5.6.7
Postby HPCplc » Wed Aug 26, 2015 6:19 pm
Ok thank you for the reply, we will setup a different folder srtucture for the 2nd group of users.
Is there anyway the banner can be changed depending on what page you are on? (eg if you are in one folder it is one image and if you are in another it is different again)
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Aug 26, 2015 10:14 pm
there is no such functionality in a default oC installation. But as oC is open source is probably just a matter of knowledge how to implement this. Maybe ask at the developers mailinglist for help if you want to implement this for yourself.
*gone*
Users browsing this forum: No registered users and 4 guests
