vhost file doesnt help with /dev/urandom not readable by php
ichse
Beginner
ownCloud version: 8.1.3
Webserver: Apache
OS: Linux Embedded
Postby ichse » Sun Sep 06, 2015 5:44 pm
my setup of OC is on a Synology DiskStation with the latest DSM (5.1).
after upgrading from OC 8.0.4 to 8.1.1 I experienced the following problem in the admin panel:
"/dev/urandom not readable by php"
I already found a fix on github, but that doesnt work for me. Im talking about that one: https://github.com/owncloud/core/issues/17465
"The addition of /dev/urandom needed to be in php_admin_value open_basedir within the vhost file"
When I navigate inside my vhost conf I see nothing like that: (which I presume it should)
Code: Select all
<Directory /usr/share/webapps/owncloud/>
    Options FollowSymlinks
    AllowOverride all
    Require all granted
    php_admin_value open_basedir "/srv/http/:/home/:/tmp/:/usr/share/pear/:/usr/share/webapps/owncloud/:/etc/webapps/owncloud:/dev/urandom"
</Directory>
So where can I find the proper vhost file? (eventhough it should be that one). How do your vhost files look like?
Mine only looks like this:
Code: Select all
NameVirtualHost *:80
<VirtualHost *:80>
ServerName *
DocumentRoot /var/services/web
</VirtualHost>
edit:
alright - I've found the solution: the line in question can be found at /etc/php/conf.d and then inside the file "user-settings.ini"
thank you for any help! best regards!
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: vhost file doesnt help with /dev/urandom not readable by
Postby RealRancor » Sun Sep 06, 2015 6:12 pm
When having an open_basedir configured within your php.ini file, make sure to include /dev/urandom.
https://doc.owncloud.org/server/8.1/adm ... ndom-label
*gone*
ichse
Beginner
Webserver: Apache
OS: Linux Embedded
Postby ichse » Sun Sep 06, 2015 6:27 pm
hi, so it has to be "...:/dev/urandom/:/dev/" ?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sun Sep 06, 2015 6:36 pm
*removed wrong text*
*gone*
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Sep 24, 2015 10:10 am
sorry but try to include /dev/urandom again instead of /dev. At my environment /dev was needed (probably because of an Bug in PHP) but /dev/urandom should be used instead.
*gone*
ichse
Beginner
Webserver: Apache
OS: Linux Embedded
Postby ichse » Thu Sep 24, 2015 2:02 pm
thx for your answer. Including "/dev/urandom" was the solution to the problem.
Best regards
