404 Error with SSL on /index.php/apps
KMyers
ownCloud version: 8.1.3
Webserver: Apache
PHP version: 5.5.9
Postby KMyers » Tue Nov 10, 2015 7:12 pm
Good Afternoon,
I have just setup a new OwnCloud instance that will be accessible over the public internet and of course went ahead and setup SSL. I can access everything perfectly while not on SSL but the second I punch in https:// things start going downhill very quickly.
While using SSL, I can hit the OwnCloud Login Page and authentication is working properly however when I get directed to https://xx.xxxx.xxx/index.php/apps/files/, I am greeted with a 404 error.
I have double checked everything I can think of and am unable to isolate the issue. I have included some of the details below in case anyone sees anything I missed.
My Server Details Are
Environment: Ubuntu x64 14.04.03
Server: Apache 2.4.7
Database: MySQL/MariaDB 5.5.46
Client: All (Firefox/Chrome/ETC)
OC-Version: 8.1.4
PHP-Version: 5.5.9
Installation Path: /var/www/owncloud
My Apache sites-enabled (SSL) - Some information has been redacted for security purposes.
<IfModule mod_ssl.c>
<VirtualHost *:443>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
ServerName cloud.kmyers.me
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15768000; includeSubDomains; preload"
</IfModule>
ServerAdmin xxxxxxxx@gmail.com
DocumentRoot /var/www/owncloud
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ErrorLog ${APACHE_LOG_DIR}/error-ssl.log
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
SSLCertificateFile /xxxxx/cert.pem
SSLCertificateKeyFile xxxxxxx/privkey.pem
Include /xxxx/options-ssl-apache.conf
SSLCertificateChainFile /etc/xxxxxxxx/chain.pem
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
</IfModule>
And for fun, my Non-SSL Sites Enabled File
<VirtualHost *:80>
ServerAdmin keithiokepamyers@gmail.com
#Redirect permanent / https://xxx.xxxx.xxx/
# modules, e.g.
#RewriteEngine on
#RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [L,QSA,R=permanent]
</VirtualHost>
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: 404 Error with SSL on /index.php/apps
Postby RealRancor » Tue Nov 10, 2015 7:19 pm
*gone*
KMyers
Webserver: Apache
PHP version: 5.5.9
Postby KMyers » Tue Nov 10, 2015 8:29 pm
Thanks, that was it.
Users browsing this forum: No registered users and 4 guests
