File Syncing & Group Qouta
naresh
ownCloud version: 8.0.11
Webserver: Apache
PHP version: 5.0
Postby naresh » Fri Apr 08, 2016 1:21 pm
Dear Concerns,
I have downloaded Owncloud 8.1.x and as well as client, i am facing some issues which are very uncomfortable with my office solution requirements.
1) When two users are saving same files ,conflict files creates after syncing.
2) Unable to implement folder or group quota .
Kindly suggest me solutions, waiting for your positive response.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: File Syncing & Group Qouta
Postby RealRancor » Fri Apr 08, 2016 1:24 pm
naresh wrote:1) When two users are saving same files ,conflict files creates after syncing.
this is the expected behavior of the sync client like described here:
https://doc.owncloud.org/desktop/2.1/ar ... lict-cases
This "conflict" then needs to be resolved by the user getting this conflict.
naresh wrote:2) Unable to implement folder or group quota .
Folder and group quotas are currently not supported by ownCloud. A feature request for group quota is available here:
https://github.com/owncloud/core/issues/1347
*gone*
naresh
Webserver: Apache
PHP version: 5.0
Postby naresh » Fri Apr 08, 2016 1:46 pm
Dear RealRancor,
Can you please suggest me some solutions other than ownCloud ??
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Fri Apr 08, 2016 4:43 pm
Not sure how many groups you have and how your structure is. What would be possible:
Set up a owncloud installation for each group and set a system quota for the data-folder. Sharing among groups is possible via federated-cloud sharing. Other option, manage all storage via external storage that supports group quotas (mounting as home directory is only supported in the enterprise edition).
naresh
Webserver: Apache
PHP version: 5.0
Postby naresh » Wed Apr 13, 2016 6:53 am
Dear,
We have 250 Users, We want a group Quota and user quota implementation on our Centralized storage, Every user must be restricted within his/her group. If any user made some changes in any file than other user of same group should unable to open that file or it should be in read only mode, after changes saved every one can access this file. We want such type of solution. Previously we were using OpenAFS solution but it creates some hanging issues at client side and we don't find any suitable solution for that. So kindly suggest me good solution according to our mentioned requirement will be highly appreciated. Thanks
