Fatal files_external
joaobrn
ownCloud version: 8.1.3
Webserver: nginx
OS: OpenBSD
PHP version: PHP56
Postby joaobrn » Thu Apr 14, 2016 1:57 am
Greetings,
I am new to the forum and for some time I use the owncloud solution.
In this way I am making some changes in my business and I decided to start using the mapping through the smbclient folders.
settings:
version of ownCloud: ownCloud 8.1.3 (stable)
Operating System: Freebsd 10.3-RELEASE
Web Server: nginx
Database: mariadb101-server10.1.13 MariaDB-client10.1.13
Packages Installed: php56-extensions php56-mysql-php56 pdo_mysql php56-zlib php56-openssl-php56 bcmath php56-gmp php56-gd php56-curl php56-ldap php56-exif-php56 fileinfo php56-mbstring php56-gmp php56-bz2 php56- php56 zip-mcrypt pecl-APCu pecl-intl
Packages compiled by portsnap: samba smbclient
What happens is that the windows when I try to map my network drives on my NAS, is running smoothly through the CIFS protocol, already in owncloud when I try to map any network drive appears the error described below:
fatal file_external
Exception: { "Exception": "Icewind \\ SMB \\ \\ ConnectException Exception", "Message", "Unknown error", "Code": 0, "Trace": "# 0 \ / usr \ / local \ / www \ / owncloud \ / apps \ / files_external \ / 3rdparty \ / Icewind \ / smb \ / src \ /Share.php (345): Icewind \\ \\ SMB Connection-> read () \ n # 1 \ / usr \ / local \ / www \ / owncloud \ / apps \ / files_external \ / 3rdparty \ / Icewind \ / smb \ / src \ /Share.php (120): Icewind \\ \\ SMB Share-> execute ( 'allinfo \ "\" ') \ n # 2 \ / usr \ / local \ / www \ / owncloud \ / apps \ / files_external \ / lib \ /smb.php (102): Icewind \\ \\ SMB Share-> stat ( '\ /') \ n # 3 \ / usr \ / local \ / www \ / owncloud \ / apps \ / files_external \ / lib \ /smb.php (136): OC Files \\ \\ \\ SMB-Storage > GetFileInfo ( '') \ n # 4 \ / usr \ / local \ / www \ / owncloud \ / lib \ / private \ / files \ / storage \ /common.php (408): OC \\ Files \\ Storage SMB-\\> stat ( '') \ n # 5 \ / usr \ / local \ / www \ / owncloud \ / apps \ / files_external \ / lib \ /config.php (499): OC \\ Files \\ Storage \\ Commonwealth> test (false) \ n # 6 \ / usr \ / local \ / www \ / owncloud \ / apps \ / files_external \ / controller \ /storagescontroller.php (132): OC_Mount_Config :: getBackendStatus ( ' \\\\ OC \\\\ \\\\ Stora Files ... ', Array, false) \ n # 7 \ / usr \ / local \ / www \ / owncloud \ / apps \ / files_external \ / controller \ /globalstoragescontroller.php(100): OCA\\Files_External\\Controller\\StoragesController->updateStorageStatus(Object(OCA\\Files_external\\Lib\\StorageConfig))\n#8 [Internal function]: OCA Files_External \\ \\ \\ Controller GlobalStoragesController-> create ( 'PUBLIC', '\\\\ OC \\\\ \\\\ Stora Files ...', Array, NULL, Array, array 100) \ n # 9 \ / usr \ / local \ / www \ / owncloud \ / lib \ / private \ / appframework \ / http \ /dispatcher.php (159): call_user_func_array (array, array) \ n # 10 \ / usr \ / local \ / www \ / owncloud \ / lib \ / private \ / appframework \ / http \ /dispatcher.php (89): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\Files_External\\Controller\\GlobalStoragesController), 'Create') \ n # 11 \ / usr \ / local \ / www \ / owncloud \ / lib \ / private \ / appframework \ /app.php (108): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Files_External\\Controller\\GlobalStoragesController), 'Create') \ n # 12 \ / usr \ / local \ / www \ / owncloud \ / lib \ / private \ / appframework \ / routing \ /routeactionhandler.php (45): OC \\ \\ AppFramework App :: main ( 'GlobalStoragesC ...', 'create', Object (OC \\ AppFramework \\ \\ DependencyInjection DIContainer), Array) \ n # 13 [internal function]: OC \\ AppFramework \\ \\ routing RouteActionHandler-> __invoke (Array) \ n # 14 \ / usr \ / local \ / www \ / owncloud \ / lib \ / private \ / route \ /router.php (274): call_user_func (Object (OC \\ \\ AppFramework routing \ \ RouteActionHandler), Array) \ n # 15 \ / usr \ / local \ / www \ / owncloud \ / lib \ /base.php (874): OC \\ \\ Route router-> match ( '\ / apps \ /files_ext...')\n#16 \ / usr \ / local \ / www \ / owncloud \ index.php (40): OC :: handleRequest () \ n # 17 {main}","File":"\/usr\/local\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Connection.php","Line":48}
Thinking it was a problem in the version of owncloud, I tried to use all the available versions that even found the last which is 9.0.1.
I wonder if anyone has gone through this problem knows solve.
I thank everyone's attention!
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Fatal files_external
Postby RealRancor » Thu Apr 14, 2016 7:10 am
try to install https://github.com/eduardok/libsmbclient-php which is recommended over the use of smbclient.
*gone*
