Calendar slow due to large 'oc_clndr_repeat' table
traxdigitizer
ownCloud version: 8.1.6
Webserver: Apache
PHP version: 5.5.47
Postby traxdigitizer » Tue May 03, 2016 3:53 pm
I'm running a Linux Debian server with ocwncloud 8.1.6 on apache/mysql/php5.5.47. I'm using 3 calendars:
- private
- business
- client-cal: this is used as a readyonly calendar. It's autmatically imported from a regularly uploaded .ICS file using https://github.com/georgehrke/cl-calendarimport. All old calendar items are deleted on import.
All calendars are synced with my iphone and ipad using native IOS caldav support, and synced with outlook using CalDav Synchronizer (https://sourceforge.net/projects/outlookcaldavsynchronizer/). Works like a charm!
However, I noticed that the webinterface has become really slow. This is caused because for some reason the 'oc_clndr_repeat' table of the database has become very big. It is 300MB in size and contains over 6.000.000 records. I'm still looking into the root cause of this problem, but I'm wondering if it is possible to remove duplicates from this table? Any suggestions? What happens when I empty this table? Will it be recreated by owncloud?
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: Calendar slow due to large 'oc_clndr_repeat' table
Postby tflidd » Wed May 04, 2016 9:20 am
The calendar app was rewritten for owncloud 9.0. So the devlopement for the old app somehow stopped. I'm not sure if bugs are still fixed at all, the bugtracker moved here: https://github.com/owncloudarchive/calendar/issues
Concerning your question if this table can be cleaned or deleted, please redirect this question directly to the developers. Use the mailinglist or IRC.
