Nginx & ownCloud setup problem
olivermtx
Postby olivermtx » Fri Jun 24, 2016 5:10 pm
I recently purchased a raspberry pi, and installed Nginx & ownCloud 8.0
I managed to get ownCloud server part to work properly, as I can connect on https://.../owncloud and upload documents over it.
But, as I downloaded the windows client, I didn't managed to connect to the server and received the following error message:
Error: Failed to connect to ownCloud at https://.../owncloud/status.php
Error downloading https://.../owncloud/status.php -server replied: Bad request
I suppose this comes from my Nginx config so I will quote it below.
Any help would be greatly appreciated.
upstream php-handler {
#server 127.0.0.1:9000;
server unix:/var/run/php5-fpm.sock;
server {
listen 80;
server_name mysite.com ;
# return 301 https://$server_name$request_uri; # enforce https
return 301 https://89.157...;
server {
listen 443 default_server ssl;
ssl_certificate /etc/nginx/ssl/nginx.crt;
ssl_certificate_key /etc/nginx/ssl/nginx.key;
root /data/mysite.com/www;
index index.php index.html;
error_page 404 /404.html;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
# Error & Access logs
error_log /data/mysite.com/logs/error.log error;
access_log /data/mysite.com/logs/access.log;
client_max_body_size 10G; # set max upload size
fastcgi_buffers 64 4K;
# ownCloud blacklist
location ~ ^/owncloud/(?:\.htaccess|data|config|db_structure\.xml|README) {
deny all;
error_page 403 = /owncloud/core/templates/403.php;
location / {
index index.html index.php;
location /owncloud/ {
error_page 404 = /owncloud/core/templates/404.php;
rewrite ^/owncloud/caldav(.*)$ /remote.php/caldav$1 redirect;
rewrite ^/owncloud/carddav(.*)$ /remote.php/carddav$1 redirect;
rewrite ^/owncloud/webdav(.*)$ /remote.php/webdav$1 redirect;
rewrite ^(/owncloud/core/doc[^\/]+/)$ $1/index.html;
# The following rules are only needed with webfinger
rewrite ^/owncloud/.well-known/host-meta /public.php?service=host-meta last;
rewrite ^/owncloud/.well-known/host-meta.json /public.php?service=host-meta-json last;
rewrite ^/owncloud/.well-known/carddav /remote.php/carddav/ redirect;
rewrite ^/owncloud/.well-known/caldav /remote.php/caldav/ redirect;
try_files $uri $uri/ index.php;
location ~ \.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
include fastcgi_params;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
# Optional: set long EXPIRES header on static assets
location ~* ^/owncloud(/.+\.(jpg|jpeg|gif|bmp|ico|png|css|js|swf))$ {
expires 30d;
access_log off; # Optional: Don't log access to assets
###### phpMyAdmin ############################################################
location /phpmyadmin {
root /usr/share/;
index index.php index.html index.htm;
location ~ ^/phpmyadmin/(.+\.php)$ {
root /usr/share/;
#include fastcgi-gen.conf;
fastcgi_pass unix:/var/run/php5-fpm.sock;
fastcgi_index index.php;
include /etc/nginx/fastcgi_params;
fastcgi_buffer_size 128k;
fastcgi_buffers 256 4k;
fastcgi_busy_buffers_size 256k;
fastcgi_temp_file_write_size 256k;
fastcgi_read_timeout 240;
location ~* ^/phpmyadmin/(.+\.(jpg|jpeg|gif|css|png|js|ico|html|xml|txt))$ {
root /usr/share/;
location /phpMyAdmin {
rewrite ^/* /phpmyadmin last;
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Nginx & ownCloud setup problem
Postby RealRancor » Sun Jun 26, 2016 2:20 pm
if you're installing a new system please directly install oC 9.0.2 and then use the known working nginx config provided here:
https://doc.owncloud.org/server/9.0/adm ... ud_9x.html
*gone*
