Slow synchro
gueulderack
ownCloud version: 7.0.2
Webserver: Apache
Database: SQLite
Slow synchro
Postby gueulderack » Fri Nov 13, 2015 11:35 pm
Hi all,
I had recently re-installed my server owncloud. Here are my versions:
OS: Ubuntu 32 bit 15.10
Apache: 2.4.12
MariaDB: 10.0.22
PHP: 5.6.11
Owncloud: 8.2.0 (Stable)
Owncloud Client: 2.0.2
Synchronization with client is very slow: 881 files for a total of 73 Mo, it takes 2h10!
But the thing is that is not the file transfer who is slow (I test with an unique big file, and I was at the maximum of my line capabilities), but it between each file that it take some times: 3-10 secondes.
The only error I have found is in the owncloud log:
Error PHP Array to string conversion at /var/www/owncloud/lib/private/template/functions.php#36
Error PHP Cannot modify header information - headers already sent by (output started at /var/www/owncloud/3rdparty/sabre/http/lib/Sapi.php:70) at /var/www/owncloud/3rdparty/sabre/http/lib/Sapi.php#58
For the first one, issue is still open.
For the second one, I don't find any real solution. But maybe I don't look at the right place!
If anyone know a part of a solution...
Thank you for helps.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Slow synchro
Postby RealRancor » Fri Nov 13, 2015 11:40 pm
unfortunately we users in here just can point you to guides and tutorials how to tweak your environment etc. like:
https://doc.owncloud.org/server/8.2/adm ... index.html
and so on. Everything else is not in "our hands". :( If there is an issue somewhere within the client or the oC server itself it should be discussed with the developers.
You could also check the issue trackers here on your own:
https://github.com/owncloud/core/issues
https://github.com/owncloud/client/issues
There where already a few issues reported about a slow sync.
*gone*
gueulderack
Webserver: Apache
Database: SQLite
Re: Slow synchro
Postby gueulderack » Sun Nov 15, 2015 12:15 am
I found the solution: redis for transactional file locking must be installed and not another one. Before, I had APCu installed.
But with Ubuntu, the last version of Redis must be installed. I followed this tutorial and it worked perfectly on my server.
https://www.en0ch.se/how-to-configure-redis-cache-in-ubuntu-14-04-with-owncloud/
If it can help someone...
Thank you for the help.
Cheers.
