Access from example.com instead of example.com/owncloud
dbolton
Beginner
ownCloud version: 9.0.1
Webserver: Apache
Postby dbolton » Thu Nov 19, 2015 9:49 am
How do I set up a new install of ownCloud so that I can access it from example.com instead of example.com/owncloud?
I'm installing ownCloud 8.2.1 on Ubuntu Server 14.04 LTS
I wonder if changing the default settings in /etc/apache2/conf-available/owncloud.conf will change this or if those directories only affect how the files are stored internally on the server:
Code: Select all
Alias /owncloud "/var/www/owncloud/"
<Directory "/var/www/owncloud">
    Options +FollowSymLinks
    AllowOverride All
    <IfModule mod_dav.c>
      Dav off
    </IfModule>
    SetEnv HOME /var/www/owncloud
    SetEnv HTTP_HOME /var/www/owncloud
</Directory>
<Directory "/var/www/owncloud/data/">
  # just in case if .htaccess gets disabled
  Require all denied
</Directory>
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Access from example.com instead of example.com/owncloud
Postby RealRancor » Thu Nov 19, 2015 9:55 am
Duplicate of viewtopic.php?f=31&t=31516 and some more existing threads.
Might be useful if some one has configured his web server correctly is writing a FAQ to avoid having asked this question over and over again.
*gone*
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Thu Nov 19, 2015 5:49 pm
Let's stick to the already existing thread.
