Files uploaded via ftp or webdav not seen on the web interfa
dandi98
Beginner
ownCloud version: 8.2.1
Webserver: Apache
Postby dandi98 » Sat Nov 21, 2015 12:56 am
Hi guys, I have a problem that I think is not just about me, after the update to version 8.2.0 when load a file in my user folder via ftp or webdav the uploaded file does not appear in the web! the absurdity that even if I delete a file from ftp remains that remains stored in the web as if you had not removed but if I try to open it tells me that the file is not available! is there a solution?otherwise I will never update my platform if this bug persists because I need to upload files via FTP! thank you in advance and I apologize for my English is not correct, but I am Italian and I am using the translator :oops: . Thanks again
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: Files uploaded via ftp or webdav not seen on the web int
Postby tflidd » Sat Nov 21, 2015 1:19 am
dandi98
Beginner
Webserver: Apache
Postby dandi98 » Sat Nov 21, 2015 11:30 am
Thanks for the answer ! then launching this command
Code: Select all
$ sudo -u www-data php occ  files:scan --all
the problem is resolved, and the files are recognized, but if you load new files via ftp to display them I raise again the script ...
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sat Nov 21, 2015 12:11 pm
Which is expected. Please read the linked post again which describes a supported way
*gone*
dandi98
Beginner
Webserver: Apache
Postby dandi98 » Sat Nov 21, 2015 9:23 pm
Hello, I tried to read one of the articles mentioned in the post tagged, but to Italian becomes really incomprehensible! you illustrarmi control repair and maybe I put a guide in Italian to solve the problem? thanks a lot
dandi98
Beginner
Webserver: Apache
Postby dandi98 » Thu Dec 10, 2015 12:59 pm
Hello, I think the code to apply is this that I just attached, but do not understand how to apply it :( unfortunately I do not speak English and I and many users after the update we find ourselves having to fight ocntro this problem! I hope for your help...
Code: Select all
$ Sudo -u www-data php file occ: scan --help
  Uso:
  File: scansione [-p | --path = "..."] [-q | --quiet] [--all] [ID_utente1] ... [user_idN]
Argomenti:
  user_id sarà ripetere la scansione di tutti i file di un determinato utente (s)
Opzioni:
  --path (-p) Limite nuova analisi a questo percorso, ad esempio.
  --path = "/ alice / files / Music", il user_id è determinata dal percorso e la
  parametro user_id e --all sono ignorati
  --all sarà ripetere la scansione di tutti i file di tutti gli utenti noti
cybero2912
Beginner
ownCloud version: 8.2.2
Webserver: Apache
PHP version: 5.6.19-1
Postby cybero2912 » Thu Dec 10, 2015 4:23 pm
RealRancor wrote:Which is expected. Please read the linked post again which describes a supported way
Sorry but this new behavior is crap.
I am using ownCloud since years and there was never a problem with uploading files via sftp,ftp,smb or whatever. They were always visible in owncloud web interface.
This is a bug in files app!
I cannot perform a "TRUNCATE oc_filecache" or "sudo -u www-data php occ files:scan --all" everytime I upload a file.
Kind Regards Robert
edit: issue opened in bugtracker
https://github.com/owncloud/core/issues/21122
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Dec 10, 2015 5:01 pm
this is not a bug and wasn't supported since the beginning. That fact is also described within the documentation:
The data directory on the server is exclusive to ownCloud and must not be modified manually.
https://doc.owncloud.org/server/8.1/adm ... ync-issues
https://doc.owncloud.org/desktop/2.0/tr ... her-issues
*gone*
cybero2912
Beginner
Webserver: Apache
Postby cybero2912 » Thu Dec 10, 2015 5:14 pm
RealRancor wrote:this is not a bug and wasn't supported since the beginning....
maybe - but it has been working since the beginning.
therefore something has been changed in 8.2 which has caused this horrible behavior.
I never use the webif for mass file uploads - only sometimes for downloading or uploading single files.
The webif is only used by my users for up and downloads.
For me ownCloud is nearly useless if it is no longer possible to upload files not using the webinterface :(
dandi98
Beginner
Webserver: Apache
Postby dandi98 » Thu Dec 10, 2015 6:28 pm
Well we will be forced to migrate to alfresco ... I had created their own script file uploading in mass via ftp ... and now I find myself not being able to update :( sin was a nice platform constantly in development but with a lack so severe changes everything!
