no client sync for files by cron.dialy copy to server dir
PowerPenguin
Beginner
ownCloud version: 8.2.1
Webserver: Apache
Postby PowerPenguin » Wed Nov 25, 2015 8:37 pm
Hi , why the client does not sync files that are copyed by cron.daily to a oc server data folder ?
The file and folder rights are alright www-data:www-data
Best regards,
PP
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: no client sync for files by cron.dialy copy to server di
Postby RealRancor » Wed Nov 25, 2015 8:48 pm
quoting from the documentation:
The data directory on the server is exclusive to ownCloud and must not be modified manually.
https://doc.owncloud.org/server/8.1/adm ... ync-issues
https://doc.owncloud.org/desktop/2.0/tr ... her-issues
As you did this unsupported modification of the data directory its very likely the source of your issue.
*gone*
PowerPenguin
Beginner
Webserver: Apache
Postby PowerPenguin » Wed Nov 25, 2015 10:37 pm
RealRancor wrote:Hi,
But was working in oder versions !
So there is no sync of mysql with server folders and you can only set up now a big music database from scratch on a new server by client upload (mysql entry) if you want to do so.
: new usb drive (new touch of files) every client has to syn the hole stuff :-) ok mv is better ..if it works on the first run :-)
Any way: Why CRC is not file time stamp depending on server in database on compare ?
First write wins ..very simple ! :roll:
Is dual ediditing of shared files supported by owncloud ..could not remember where this was mentioned !
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Wed Nov 25, 2015 11:53 pm
PowerPenguin wrote:But was working in oder versions !
You can use the external storage feature to include other directories on your server (where you can upload files via SFTP/FTP/SMB/NFS/...). There are several problems, you can probably deal with it if you modify the right places in the database but it is not officially supported: https://github.com/owncloud/documentation/pull/1588
PowerPenguin wrote:Any way: Why CRC is not file time stamp depending on server in database on compare ?
I think they are currently working on something with file-hashing: https://github.com/owncloud/core/issues/11811 (helping hands are probably welcome).
PowerPenguin
Beginner
Webserver: Apache
Postby PowerPenguin » Thu Nov 26, 2015 7:21 pm
solved partly: If you want to distribute manuals .pdf or news .ebub (calibre) you can update the single "download only" folder with this "abuse" command in your cron job after you copyed the stuff to oc server folder
e.g.: for /Books/News
sudo -u www-data php occ -all --path=/<oc_user_name>/Books/News
files:scan [-p| --path="..."] [-q| --quiet] [--all] [user_id1] .. [user_idN]
in the call cron.daily bash sript you do not need sudo
and you should execute from or cd to /var/www/owncloud
Ok how to execute as www-data in script called by root (cron) is still open.. I have to google because www-data has no login :?:
Best regards,
PP
