Configuring Memcached on SiteGround server
User avatar
GJSchaller
Beginner
ownCloud version: 8.2.2
Webserver: Apache
Database: SQLite
OS: Linux Hosting Package
PHP version: 5.6
Contact:
Postby GJSchaller » Wed Dec 30, 2015 9:04 pm
I'm working with OwnCloud 8.2.1 on a SiteGorund hosted server running PHP 5.6. Memcached is enabled, with the following information provided by SiteGround:
Your credentials for activating Memcached:
Your IP address: 127.0.0.1
Your port: 20000
I'm attempting to add this to my config.php, but the example given at https://doc.owncloud.org/server/8.2/adm ... ation.html lists APCu as the local cache, which is confusing...
This is my entry for config.php, which gives me the error listed after it:
'memcache.local' => '\OC\Memcache\Memcached',
'memcache.distributed' => '\OC\Memcache\Memcached',
'memcached_servers' =>
array (
0 =>
array (
0 => '127.0.0.1',
1 => 20000,
<link rel="shortcut icon" type="image/png" href="Memcache \OC\Memcache\Memcached not available for local cache Is the matching PHP module installed and enabled?
Any idea what I am missing in my config.php to make this work properly?
Thank you for your help!
Geoffrey Schaller
Web Guy
http://www.knightrealms.com
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Configuring Memcached on SiteGround server
Postby RealRancor » Wed Dec 30, 2015 10:51 pm
Have you checked with an phpinfo page if the php module is really loaded?
*gone*
User avatar
GJSchaller
Beginner
Webserver: Apache
Database: SQLite
PHP version: 5.6
Contact:
Postby GJSchaller » Wed Dec 30, 2015 11:26 pm
It's showing as active, yes:
memcache support enabled
Active persistent connections 0
Version 2.2.6
Revision $Revision: 303962 $
Geoffrey Schaller
Web Guy
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Dec 31, 2015 1:11 pm
memcache is not memcached so you're missing the memcached module
*gone*
User avatar
GJSchaller
Beginner
Webserver: Apache
Database: SQLite
PHP version: 5.6
Contact:
Postby GJSchaller » Thu Dec 31, 2015 3:12 pm
I asked SiteGround support if it was memcached, or just memcache... They had said it was memecached. I'll go back and hit them up again.
Geoffrey Schaller
Web Guy
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Dec 31, 2015 3:47 pm
Yes, they are providing memchached according your initial post but your phpinfo output is showing the memcache php module enabled which is not the correct module.
*gone*
User avatar
GJSchaller
Beginner
Webserver: Apache
Database: SQLite
PHP version: 5.6
Contact:
Postby GJSchaller » Thu Dec 31, 2015 4:35 pm
I have verified it's enabled on my account, using cPanel. Now the trick will be: what's the proper configuration in config.php to use it?
Geoffrey Schaller
Web Guy
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Dec 31, 2015 4:37 pm
Verifying in cpanel won't work. You need to check your phpinfo that the memcached (not memcache) module is loaded.
*gone*
User avatar
GJSchaller
Beginner
Webserver: Apache
Database: SQLite
PHP version: 5.6
Contact:
Postby GJSchaller » Thu Dec 31, 2015 5:42 pm
This is the response from SiteGround:
I double checked the server and the Memcached service is running for your owncloud cPanel user:
Code: Select all
owncloud 30665 0.0 0.0 292228 1004 ? Ssl 08:31 0:00 /usr/bin/memcached -d -p 20000 -u owncloud -m 64 -c 256 -P /var/run/memcached/owncloud/memcached-20000.pid -l 127.0.0.1
The server that you should use for your application is 127.0.0.1 and the port is 20000.
That being said, what is the proper entry in config.php to use this? I'm trying the following:
'memcached_servers' => array(
array('127.0.0.1', 20000),
Geoffrey Schaller
Web Guy
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Dec 31, 2015 5:53 pm
Still the PHP module for memcached is missing. This is not about the memcached server itself, those are two completely different components.
*gone*
