Problem changing datadirectory
Tester_owncloud2
Postby Tester_owncloud2 » Fri Feb 12, 2016 1:58 pm
I have the following problem:
I've installed apache2, owncloud and so on my raspberry pi but on the screen http://<IP>/owncloud/ where I create the admin user for first time I cannot select /media/pi/Nube/ as data directory, I was only capable of choosing /var/www/html/owncloud/data/
This is the way how /media/pi/Nube/ is mounted
/dev/sda7 on /media/pi/Nube type ext3 (rw,nosuid,nodev,relatime,errors=remount-ro,data=ordered,uhelper=udisks2)
And those are the permissions of /media/pi/Nube/
drwxrwxrwx 2 www-data www-data 4096 Feb 12 10:30 /media/pi/Nube
I've checked that users even different from www-data can write files inside the folder, for example I tried "touch test" for the user called pi
I've also tried to accept what it proposes and make my data directory in /var/www/html/owncloud/data and then I've changed config.php and the field datadirectory as /media/pi/Nube I also copied with the same permissions the folder called data to /media/pi/Nube, but the problem still perssits.
Some help, please? could it has to do with the apache configuration which maybe doesn't allow me access/modify directories over /var/www/html/?
Thanks in advance
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Problem changing datadirectory
Postby RealRancor » Fri Feb 12, 2016 2:14 pm
*gone*
User avatar
cdamken
Helpful Elf
ownCloud version: 8.2.2
Webserver: Apache
PHP version: 5.5.9
Contact:
Postby cdamken » Tue May 31, 2016 3:41 pm
my personal recommendation (an easier way instead modifying whole oc_filecahe in the database)
instead moving the data folder, create a symbolic link pointing to the same direction from your new storage point to the original data folder should be.
