Encryption error
happyfeet
Starter
ownCloud version: 5.0.10
Webserver: nginx
PHP version: 5.3
Contact:
Encryption error
Postby happyfeet » Sun Feb 28, 2016 2:46 pm
I would encrypt with the occ command the files on the server. But I get this message:
Code: Select all
Encrypt all files with the Default encryption module
Create key-pair for every user
This module will encrypt all files in the users files folder initially.
Already existing versions and files in the trash bin will not be encrypted.
 Key-pair created for all users
Start to encrypt users files
 encrypt files for user Anja (1 of 3): /Anja/files/ownCloud_User_Ma encrypt files for user Anja (1 of 3): /Anja/files/ownCloud_User_Manual.pdf.encrypted.1456659252 ]
 encrypt files for user Anja (1 of 3): /Anja/files/ownCloud_User_Manual.pdf.encrypted.1456663706
 encrypt files for user Anja (1 of 3): /Anja/files/Photos/Paris.jpg
 [---->-----------------------]        PHP Fatal error:  Call to a member function get() on a non-object in /var/www/owncloud/apps/music/utility/scanner.php on line 289
PHP Stack trace:
PHP   1. {main}() /var/www/owncloud/occ:0
PHP   2. require_once() /var/www/owncloud/occ:11
PHP   3. OC\Console\Application->run() /var/www/owncloud/console.php:69
PHP   4. Symfony\Component\Console\Application->run() /var/www/owncloud/lib/private/console/application.php:100
PHP   5. Symfony\Component\Console\Application->doRun() /var/www/owncloud/3rdparty/symfony/console/Symfony/Component/Console/Application.php:126
PHP   6. Symfony\Component\Console\Application->doRunCommand() /var/www/owncloud/3rdparty/symfony/console/Symfony/Component/Console/Application.php:195
PHP   7. Symfony\Component\Console\Command\Command->run() /var/www/owncloud/3rdparty/symfony/console/Symfony/Component/Console/Application.php:874
PHP   8. OC\Core\Command\Encryption\EncryptAll->execute() /var/www/owncloud/3rdparty/symfony/console/Symfony/Component/Console/Command/Command.php:253
PHP   9. OCA\Encryption\Crypto\Encryption->encryptAll() /var/www/owncloud/core/command/encryption/encryptall.php:122
PHP  10. OCA\Encryption\Crypto\EncryptAll->encryptAll() /var/www/owncloud/apps/encryption/lib/crypto/encryption.php:446
PHP  11. OCA\Encryption\Crypto\EncryptAll->encryptAllUsersFiles() /var/www/owncloud/apps/encryption/lib/crypto/encryptall.php:145
PHP  12. OCA\Encryption\Crypto\EncryptAll->encryptUsersFiles() /var/www/owncloud/apps/encryption/lib/crypto/encryptall.php:202
PHP  13. OCA\Encryption\Crypto\EncryptAll->encryptFile() /var/www/owncloud/apps/encryption/lib/crypto/encryptall.php:233
PHP  14. OC\Files\View->unlink() /var/www/owncloud/apps/encryption/lib/crypto/encryptall.php:258
PHP  15. OC\Files\View->basicOperation() /var/www/owncloud/lib/private/files/view.php:604
PHP  16. OC\Files\View->runHooks() /var/www/owncloud/lib/private/files/view.php:1013
PHP  17. OC_Hook::emit() /var/www/owncloud/lib/private/files/view.php:1136
PHP  18. call_user_func:{/var/www/owncloud/lib/private/hook.php:103}() /var/www/owncloud/lib/private/hook.php:103
PHP  19. OCA\Music\Hooks\File::deleted() /var/www/owncloud/lib/private/hook.php:103
PHP  20. OCA\Music\Utility\Scanner->deleteByPath() /var/www/owncloud/apps/music/hooks/file.php:27
Owncloud.log
Code: Select all
a member function get() on a non-object at \/var\/www\/owncloud\/apps\/music\/utility\/scanner.php#289","level":3,"time":"2016-02-28T13:48:30+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"OC\\Files\\Cache\\Scanner","message":"!!! Path 'files\/ownCloud_User_Manual.pdf.encrypted.1456663769' is not accessible or present !!!","level":0,"time":"2016-02-28T13:49:32+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"core","message":"unable to rename, file does not exists : files\/ownCloud_User_Manual.pdf.encrypted.1456663769","level":3,"time":"2016-02-28T13:49:32+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"OC\\Files\\Cache\\Scanner","message":"!!! Path 'files\/ownCloud_User_Manual.pdf.encrypted.1456659252.encrypted.1456663772' is not accessible or present !!!","level":0,"time":"2016-02-28T13:49:36+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"core","message":"unable to rename, file does not exists : files\/ownCloud_User_Manual.pdf.encrypted.1456659252.encrypted.1456663772","level":3,"time":"2016-02-28T13:49:36+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"OC\\Files\\Cache\\Scanner","message":"!!! Path 'files\/ownCloud_User_Manual.pdf.encrypted.1456663706.encrypted.1456663776' is not accessible or present !!!","level":0,"time":"2016-02-28T13:49:41+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"core","message":"unable to rename, file does not exists : files\/ownCloud_User_Manual.pdf.encrypted.1456663706.encrypted.1456663776","level":3,"time":"2016-02-28T13:49:41+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"no app in context","message":"Can not decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.","level":3,"time":"2016-02-28T13:49:43+01:00","method":"--","url":"--"}
{"reqId":"d3CEsgOOXZmAvfZ2dTeN","remoteAddr":"","app":"PHP","message":"Call to a member function get() on a non-object at \/var\/www\/owncloud\/apps\/music\/utility\/scanner.php#289","level":3,"time":"2016-02-28T13:49:46+01:00","method":"--","url":"--"}
Server:
Ubuntu 14.04
Mysql
Client:
OC-Version:
8.2.2
PHP-Version:
5.5.32
Can anyone help me?
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: Encryption error
Postby tflidd » Mon May 30, 2016 5:40 pm
Please report this to the bugtracker: github.com/owncloud/core/issues
