Problem with php occ files:scan -all
cstolze
ownCloud version: 8.2.2
Webserver: Apache
PHP version: 5.5.9
Postby cstolze » Mon Feb 29, 2016 3:23 pm
Environment: Ubuntu 14.4
Server: Apache 2
Database: MySql 5.5
Client: 2.1.1
OC-Version: 8.2.2
PHP-Version:5.5.9
I use a php script on the webserver which use the php command
Code: Select all
exec('php /srv/owncloud/console.php files:scan --all');
It was working fine under ubuntu 12 (I guess it was php 5.4 or 5.6). Now after the update to ubuntu 14 the system crash when using the command or alternative the
Code: Select all
exec('php /srv/owncloud/occ files:scan --all');
command. I use the script to force a sync without waiting if needed. Because it seems to me, that you cant trust the update times between the diffrent computers and devices we use. Anyone have an idea? I searched the web and the forum, but didnt get any answer which solve the problem. I dont need sudo -user www-data, because the script allready is using this user to run.
GYJohn
Beginner
Webserver: Apache
PHP version: 5.6.14
Re: Problem with php occ files:scan -all
Postby GYJohn » Thu Mar 03, 2016 4:41 pm
Did u tried the command without the php file?
Just at the server like sudo -u www-data php occ files:scan --all ?
cstolze
Webserver: Apache
PHP version: 5.5.9
Postby cstolze » Mon Mar 07, 2016 9:46 am
Yes, the admin tried this and he said it works.
cstolze
Webserver: Apache
PHP version: 5.5.9
Postby cstolze » Tue May 24, 2016 1:25 pm
We updated to OC version 9.0.2 but I still can't force the file sync out of my php script. ANy ideas ?
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue May 24, 2016 1:30 pm
You're probably just not supposed to run the occ command from a PHP script via the webserver.
*gone*
cstolze
Webserver: Apache
PHP version: 5.5.9
Postby cstolze » Tue May 24, 2016 2:43 pm
Owner of the occ file is www-data, which have the right to execute the occ file, but we updated PHP. It worked before the update, so there meight be missing a module or some settings are diffrent. Any idea where to look ?
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Tue May 24, 2016 2:45 pm
Your php configuration? Logfiles?
