HTTP Logs from owncloud:8.2.2-fpm
otbe0
Postby otbe0 » Mon Feb 29, 2016 9:06 pm
Hi everybody,
I wonder why I get HTTP traffic logs from my brand new owncloud 8.2.2-fpm docker container. Im using docker compose to spin up instances from owncloud (fpm), mysql, redis and nginx as reverse proxy and Im very happy how it works together. But for no reason (to me) Im getting HTTP logs from owncloud as well.
What I mean is docker-compose logs outputs the following (app=owncloud;web=nginx):
Code: Select all
app_1 myIp - user 29/Feb/2016:19:05:20 +0000 \"PROPFIND /remote.php\" 207
web_1 myIp - user [29/Feb/2016:19:05:20 +0000] \"PROPFIND /remote.php/webdav/ HTTP/1.1\" 207 {...}
Im not an php or php-fpm expert, so this could be disabled somewhere but googling around didn't helped me a lot :(
Any advices?
Thank you.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: HTTP Logs from owncloud:8.2.2-fpm
Postby RealRancor » Mon Feb 29, 2016 9:11 pm
probably due to stuff like datadirectory security and webdav checks which are done if you're browse to the admin backend of your oC instance.
*gone*
otbe0
Postby otbe0 » Mon Feb 29, 2016 9:15 pm
Sorry for my misleading example. This redundant logging behavior applies to all requests:
Code: Select all
app_1 myIp -  29/Feb/2016:19:20:22 +0000 \"GET /index.php\"
web_1 myIp - - [29/Feb/2016:19:20:22 +0000] \"GET /index.php/core/ajax/share.php?fetch=getItemsSharedStatuses&itemType=file HTTP/1.1\" 200  {...}
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Mon Feb 29, 2016 9:42 pm
Mhhh, no idea then. Maybe ask at a community dedicated to such webserver setups. They probably have more knowledge about that. Especially as ownCloud itself is not doing any logging.
*gone*
otbe0
Postby otbe0 » Mon Feb 29, 2016 10:22 pm
Okay, I got it.
The problem is the way how the php docker image is configured and owncloud relies on this image. It redirects error logs to stderr and the access log for www applications to stdout. There is a config file at /usr/local/etc/php-fpm.d/docker.conf within the docker image.
Code: Select all
[www]
; disable this because we have nginx :)
; if we send this to /proc/self/fd/1, it never appears
access.log = /proc/self/fd/2
If you comment out access.log the redundant logging stops.
Thank you.
