Problem after update 8.2.5 File access
Sudarky
ownCloud version: 8.2.3
Webserver: Apache
Postby Sudarky » Mon May 23, 2016 12:09 pm
Hello
After an update last night from my owncloud,
I no longer access the file that load continues without bring up my files. I do not understand why against by my public links still works.
Can you help me ?
Code: Select all
Error   PHP   Comments starting with '#' are deprecated in /etc/php5/apache2/conf.d/ming.ini on line 1 at Unknown#0
I use a translation I am French I hope to have your help.
Thank you
cordially
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Problem after update 8.2.5
Postby RealRancor » Mon May 23, 2016 12:46 pm
i think this message is unrelated to your issue. You can fix your PHP configuration like described here:
https://stackoverflow.com/questions/140 ... ge-via-cli
and see if there are any other errors in the logfiles.
*gone*
Sudarky
Webserver: Apache
Postby Sudarky » Mon May 23, 2016 12:49 pm
Okay thank you so much.
I thought it was related to my problem.
But it's really weird I had already made the automatic update day and she had run I see no reason why that last night it makes me load my page without being able to give me my host files.
Sudarky
Webserver: Apache
Re: Problem after update 8.2.5 File access
Postby Sudarky » Tue May 24, 2016 2:07 pm
Hello
Nobody has a solution?
How can I restore the old version?
tflidd
Forum Moderator
Webserver: Apache
Postby tflidd » Tue May 24, 2016 2:12 pm
Check your logfiles: viewtopic.php?f=17&t=7330
If you need to go back, you have to use your backup which should be done before you run an update/upgrade.
