Can't access Owncloud: An exception occured in driver: SQLSTATE[HY000] [2002]
steph.morin
ownCloud version: 8.2.3
Webserver: Lighttpd
OS: OpenBSD
PHP version: 5.6
Postby steph.morin » Sat Jul 02, 2016 4:14 pm
1. try to connect to owncloud by browser or sync tool
Owncloud accessible
Internal server error message,
Environment:Home server
Server: lighthttpd on freebsd 10.2
Database: Mysql 5.6
Client: Any
OC-Version: 8.2.5.2
PHP-Version: 5.6
Owncloud became non-responsive (unable to connect with the desktop sync tool and webpage), so I restarted services (restart the jail).
After the restart, I get the following error when accessing Owncloud:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
The events worthy of mention in Owncloud log:
On June 24th, I upgraded the OC version as follow:
"message":"starting upgrade from 8.2.2.2 to 8.2.5.2","level":0
Then the log is quiet until yesterday (July 1):
Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Pictures\\\/Lightroom\\\/Lightroom 5 Catalog.lrcat-chunking-121536809-149-148\\\" is locked\"
and
message":"Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Connection refused","level":4
Not sure if this has anything to do with the issue, but the file Lightroom 5 Catalog.lrcat is big.
When I try to connect directly to Mysql, I get the following
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
I tried to change localhost to 127.0.0.1 as mentionned in some forums, no success.
I tried to stop/start Mysql with the console, but get the following error
"mysql not running? (check /var/db/mysql/owncloud.local.pid)."
Would anyone have suggestions for the next steps to resolve this issue? Or should I simply restore the last backup of the database? (I have a daily backup scheduled with the following command "/usr/local/bin/mysqldump --lock-tables -h localhost -u ....")
Thank you for your help
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Can't access Owncloud: An exception occured in driver: SQLSTATE[HY000] [2002]
Postby RealRancor » Sat Jul 02, 2016 4:28 pm
your mysql server is currently not running and causing the shown issue:
Connection refused
Its hard to tell from remote why this is happening in your environment and what caused this but those errors might be a good starting point for a research on the net. A FreeBSD community might also be able to help here, maybe its related to your jail setup?
*gone*
steph.morin
Webserver: Lighttpd
OS: OpenBSD
PHP version: 5.6
Postby steph.morin » Sat Jul 02, 2016 4:36 pm
What is odd is that this setup has worked fine for over 2 years.
When checking server processes, Mysql is up and process id's are present. This looks like a table corruption that might have been caused by something in the recent upgrade I made to 8.2.5.
My next step is likely a restore of my backup, but I would like to avoid that as I would lose 1 day of activities
sm
steph.morin
Webserver: Lighttpd
OS: OpenBSD
PHP version: 5.6
Postby steph.morin » Wed Jul 06, 2016 4:37 am
For others that may one day have the same issue.. not sure what caused it, but Mysql would no longer start in the freebsd jail it was running. May have been caused by a update of freebsd or database corruption.. I don't think I'll ever know.
So the fix for me was to rebuild a new jail and reinstall everything from scratch, then restore the database backup I had.
Steph
