Why OC8.2.6 always create files_trashbin and files_versions folders?
djoe07
Beginner
ownCloud version: 6.0.0a
Webserver: nginx
Database: SQLite
PHP version: 5.3.8
Postby djoe07 » Fri Jul 08, 2016 11:01 am
My OC8.2.6 create files_trashbin and files_versions folders in my external storage regularly.
I had solved this issue by running occ files:scan --all, but after a couple of days, those folders appear again (only on the client side, on the server side those folders doesn't exist).
Of course when those folders are "created" I have errors during the syncing :
Error downloading https://.../my_external_storage/files_v ... 1467271128 - server replied: Service unavailable
trashbin and files_versions folders are created on the client side, with all my directory, but there are no files (the versioned file).
Best regards!
djoe07
Beginner
Webserver: nginx
Database: SQLite
PHP version: 5.3.8
Re: Why OC8.2.6 always create files_trashbin and files_versions folders?
Postby djoe07 » Tue Jul 12, 2016 8:19 am
One again more..
A full resync with occ files:scan --all resolve the issue.
During 3 days, no issue. Now (perhaps after a file change), files_versions and files_trashbin folders are create in two external storage...
Is an upgrade to v9 can solve this issue?
I don't really like to run the last version.. But if it solve the issue, it's a good reason to migrate...
The sync client on each client's computers are in version 2.2.2.
Thank you,
Mc/
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Tue Jul 12, 2016 4:51 pm
Normally, the files_trashbin and files_versions folders should be in your /path/to/owncloud/data/username-folder and not on the external storage itself. You data/-folder is working properly? Did you move your data/-folder?
