Upload huge file via web [SOVED]
sirio81
Beginner
Postby sirio81 » Mon Jul 18, 2016 12:34 pm
I'm trying to setup owncloud in a way that it allows the upload of huge file (i.e. 4G or more).
- Upload a file of 1G
- The upload should complete
- Web interface shows internal server error
- On onwcloud file list there's not the file I was trying to upload or its size is partial
- On /var/log/apache2/error.log I get
Code: Select all
mod_fcgid: process 51583 graceful kill fail, sending SIGKILL
Operating system: ubuntu 14.04
Web server: apache2
Database: mysql
PHP version: 5.5
ownCloud version (see ownCloud admin page): 8.2.6
Updated from an older ownCloud or fresh install: 8.1.x
ownCloud log (data/owncloud.log): nothing to show
I changed my .user.ini like this:
Code: Select all
upload_max_filesize=10G
post_max_size=10G
memory_limit=512M
mbstring.func_overload=0
always_populate_raw_post_data=-1
default_charset='UTF-8'
output_buffering=off
php_value upload_max_filesize = 10G
php_value post_max_size = 10G
php_value max_input_time -1
php_value max_execution_time -1
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Upload huge file via web
Postby RealRancor » Mon Jul 18, 2016 12:42 pm
try to switch to the only officially supported mod_php and also upgrade to a newer PHP version. The release announcement of PHP 5.6 for example lists:
File uploads larger than 2 gigabytes in size are now accepted.
https://secure.php.net/releases/5_6_0.php
Such upload stuff are handled within PHP and if a fcgid process is failing its a sign that there is something broken or buggy in PHP itself. Normally there is nothing what can be done from oC side except the suggestion to use the sync client.
*Edit*
Ah, and those are wrong and probably ignored by your webserver:
Code: Select all
The PHP .user.ini has no php_value options appended to the config options.
*gone*
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Mon Jul 18, 2016 1:07 pm
Sorry, forgot to mention (besided the edits above):
You might want to dig deeper into your logfiles (not only the apache log, maybe fcpid is logging different) which could lead to some addition hints about this issue.
*gone*
sirio81
Beginner
Postby sirio81 » Mon Jul 18, 2016 3:08 pm
Thank you very much for the precious advices.
I tested the same owncloud version on my laptop: debian 8 and I was able to upload 10G of file.
A side note that I found interesting: to upload a 10G file you need at least 20G free on your /tmp because owncloud doesn't move the uploaded file but it copies it.
So during the copy it will use 20G.
