Webdav issue
mimss
ownCloud version: 8.2.3
Webserver: Apache
PHP version: 5.5
Webdav issue
Postby mimss » Mon Jul 18, 2016 1:02 pm
1. Open owncloud android app (official)
2.type https://.../remote.php/webdav
I guess the app should say server ok
Erroneous server configuration
Operating system: Raspbian
Web server: apache2
Database: Mysql
PHP version: 5.6.22
ownCloud version (see ownCloud admin page): 8.2.6
Code: Select all
require_once(): Failed opening required '/appinfo/v1/webdav.php' (include_path='/usr/share/owncloud/3rdparty/phpseclib/phpseclib/phpseclib:/usr/share/owncloud/3rdparty/pear/console_getopt:/usr/share/owncloud/3rdparty/pear/archive_tar:/usr/share/owncloud/3rdparty/pear/pear_exception:/usr/share/owncloud/3rdparty/pear/pear-core-minimal/src:/usr/share/owncloud/lib/private:/usr/share/owncloud/config:/usr/share/owncloud/3rdparty:/usr/share/owncloud/apps:/usr/share/owncloud/lib:.:/usr/share/php:/usr/share/pear:/usr/share/owncloud') at /usr/share/owncloud/remote.php#137
I don't have this file in the owncloud folder nor any webdav.php.
Do I need to install a module?
Regards
tflidd
Forum Moderator
Webserver: Apache
Re: Webdav issue
Postby tflidd » Wed Jul 20, 2016 4:56 pm
The paths given in the error-log should normally exist. Can you verify if your code is complete:
