external site module add function for auto-login external site ?
onekid0
ownCloud version: 8.2.4
Webserver: Apache
Database: SQLite
Postby onekid0 » Wed Jul 20, 2016 11:13 am
Hi all,
I do not know if it is the good place to make the request. But I wish to carry out a change on module external site. I wish to be able to transmit the login/password of using OC running in a URL.
I looked at how Rainloop for part SSO (auto--login IMAP). It uses a lib rainloophelper.php which takes again information of authentification OC and broadcasts it in protocol IMAP.
I wish to be able to apply the same principle to module “external site”. Being in mode LDAP, that allows to authenticate my users automatically on each external application to connect to my LDAP.
That enables me to place urls in HTTP Digest or form authentification.
Code: Select all
eg : https://{OC:LOGIN}:{OC:PWD}@myapp.externalsiteldapsso.com
eg : https://www.myexternalsitessoldap.com/index.php?username={OC:LOGIN}&password={OC:PWD}
Operating system:Linux
Web server: Apache2
Database:SQLite
ownCloud version (see ownCloud admin page):8.2.4
Updated from an older ownCloud or fresh install: older
LDAP Module Work fine.
Rainloop Module Work fine and autologin working fine.
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: external site module add function for auto-login external site ?
Postby tflidd » Wed Jul 20, 2016 12:08 pm
onekid0 wrote:Hi all,
No: viewtopic.php?f=32&t=23696
