Have to add index.php to URL, or else Internal Server Error
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
schnyd
Beginner
ownCloud version: 9.0.0
Webserver: Apache
PHP version: 7
Postby schnyd » Fri Mar 18, 2016 11:11 pm
After using OC 8.2 for a while without problems, I now installed a fresh OC9. But suddenly I have to add the /index.php to reach my site. And after I log out, the site automatically switches to sub.domain.tld instead of the sub.domain.tld/index.php. So there allways is the Internal Server Error after logout.
To make things clear: It is a fresh install, nothing to do with the (still installed and running) OC8 I used untill yesterday (and still am, as long as this index.php error haunts me :lol: )
1. installed fresh OC 9
After installing, I would be able to see the login screen using sub.domain.tld
After installation there was an Internal Server Error. After adding the /index.php to my URL, everything worked fine. And, wafter logout, Internal Server Error again (I think because of the still missing index.php)
Operating system: Linux
Web server: Apache
Database: MariaDB
PHP version: 7
ownCloud version (see ownCloud admin page): 9
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): none
Thank you for any help!
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: Have to add index.php to URL, or else Internal Server Error
Postby tflidd » Fri Mar 18, 2016 11:21 pm
The error with the index.php is a problem with the rewriting rules in the .htaccess-file, you can remove this line manually:
https://github.com/owncloud/core/pull/23029/files
If you still have this internal-server error, you need to check the error-logfile of your webserver.
schnyd
Beginner
Webserver: Apache
PHP version: 7
Postby schnyd » Fri Mar 18, 2016 11:27 pm
tflidd wrote:The error with the index.php is a problem with the rewriting rules in the .htaccess-file, you can remove this line manually:
Oh man, thank you very much. I already tried editing the htaccess, but, as it seems, I edited it the wrong way. It works, thanks!
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sat Mar 19, 2016 12:54 am
This is also listed here as a known issue: viewtopic.php?f=38&t=33274
*gone*
Return to “ownCloud Server 9.0”
