configure Softlayer Object Storage as external storage
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
gilli_vj
ownCloud version: 9.0.0
Webserver: Apache
PHP version: 5.4.16
Postby gilli_vj » Thu Mar 24, 2016 6:09 am
Hi Support,
I need to add SoftLayer Object Storage as external storage.
Softlayer provides following as account credential :-
- Authentication Endpoint
- Username
- API Key (Password)
In ownclod config, we need to fill-in following mandatory fields:-
- Bucket
- USername
- Password
- Tenant name
- Identity Endpoint URL
Based on both config, i can match username, password, endpoint URL, but, not sure on Tenant name name bucket.
Please help guide me on this configuration. I can't find resources related to such configs.
Thank you.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: configure Softlayer Object Storage as external storage
Postby RealRancor » Thu Mar 24, 2016 7:13 am
are you sure that this external storage type is supported by ownCloud?
*gone*
gilli_vj
Webserver: Apache
PHP version: 5.4.16
Postby gilli_vj » Thu Mar 24, 2016 8:15 am
Thanks for the response and Yes, Its supported by Owncloud as the solution based on OpenStack Object Storage project (code-named Swift).
https://sldn.softlayer.com/article/Introduction-Object-Storage
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Mar 24, 2016 8:19 am
ah than its fine. Have a look at this available configuration:
https://doc.owncloud.org/server/9.0/adm ... stack.html
If you're missing some required info from softlayer.com which is needed by ownCloud maybe ask their support for those info?
*gone*
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Mar 24, 2016 8:58 am
Ah, forgot to mention. As an alternative you could also create an issue at:
https://github.com/owncloud/documentation/issues
asking to provide more info how to configure that object storage. Most people in this forums are just end- or home-users not using such external storages.
*gone*
gilli_vj
Webserver: Apache
PHP version: 5.4.16
Postby gilli_vj » Sun Mar 27, 2016 6:19 am
Hey, Thank you very much for your kind advice. :) I'll try create a issue there and see what could be done next.
gilli_vj
Webserver: Apache
PHP version: 5.4.16
Postby gilli_vj » Mon Mar 28, 2016 10:11 am
Guys, at the end, i managed to attach the Softlayer Object Storage as SFTP works!
Return to “ownCloud Server 9.0”
