after switching to OwnCloud 9 I cannot get the Calender in Thunderbird working.
Yes, I changed the url from remote.php/caldav to remote.php/dav.
It works on my phone, but not on Thunderbird (neither windows nor linux), anyone having the same problem?
Thunderbird Lightning OC9 CalDav
- Newbie
- ownCloud version: 9.0.0
- Webserver: Apache
- Database: MySQL
- OS: Linux
- ownCloud master
- ownCloud version: 9.0.2
- Webserver: nginx
- Database: MySQL
- OS: Linux
- PHP version: 7.0.x
Re: Thunderbird Lightning OC9 CalDav
please try again with the upcoming oC 9.0.1 bringing a lot of fixes for the CalDAV and CardDAV topics. This version will be released in around 2-3 days.
If that doesn't work please specify "I cannot get the Calender in Thunderbird working" as this cleary contains zero information about your issue.
*gone*
- Newbie
- Webserver: Apache
- Database: MySQL
- OS: Linux
OK thanks, I'll wait till then and report again.
Regarding the issue: Since Thunderbird does not have any activity viewer for lightning I know about it's hard for me to pinpoint the problem.
After adding a calendar as caldav with address https://<owncloud-url>/remote.php/dav/<calname> the calendar in the sidebar is just gray and stays gray, no matter how I try to activate it.
- ownCloud master
- Webserver: nginx
- Database: MySQL
- OS: Linux
Schakal_No1 wrote:https://<owncloud-url>/remote.php/dav/<calname>
Not quite sure but this URL might be wrong. oC 8.2.x had used something like:
https://<owncloud-url>/remote.php/webdav/calendars/<Username>/<calname>
Where did you get that used URL from?
*gone*
- Similar Topics
- Replies
- Views
- Last post
alte Termine mit Thunderbird/Lightning synchronisieren
by Feel-X » Sun Sep 13, 2015 5:08 pm » in Deutsch - 3
- 691
by RealRancor
View the latest post
Mon Sep 14, 2015 6:39 am
publish Thunderbird Lightning calendar to ownCloud 8.1
by mathrock74 » Fri Mar 04, 2016 4:03 pm » in ownCloud Server 8.0 and 8.1 - 1
- 568
by RealRancor
Fri Mar 04, 2016 4:17 pm
OC 8.1.1, Calendar 0.7.3, Thunderbird/Lightning import issue
by AndreG » Sat Aug 29, 2015 2:45 pm » in ownCloud Server 8.0 and 8.1 - 2
- 695
by AndreG
Sun Aug 30, 2015 10:29 am
- 3
- 437
by lister171254
Mon Jan 18, 2016 6:30 am
- 7
- 567
by RealRancor
Tue Mar 08, 2016 5:42 pm
Return to “ownCloud Server 9.0”
