Minimizing the number of modules for ownCloud on apache
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
darksky
ownCloud version: 9.0.2
Webserver: Apache
PHP version: 7.0.8
Postby darksky » Sat Jul 02, 2016 12:19 am
My goal is to minimize the number of modules I am loading in an attempt to streamline the server. My setup is pretty basic:
*apache 2.4.20
*owncloud 9.0.2
*mariadb
*php
*ssl
Below is my modules section of /etc/httpd/conf/httpd.conf and I'm hoping to get some feedback from folks with more apache knowledge than I. Question: which of these are not needed for my setup?
Modules enabled by the default Arch package:
Code: Select all
access_compat_module modules/mod_access_compat.so
alias_module modules/mod_alias.so
auth_basic_module modules/mod_auth_basic.so
authn_core_module modules/mod_authn_core.so
authn_file_module modules/mod_authn_file.so
authz_core_module modules/mod_authz_core.so
authz_groupfile_module modules/mod_authz_groupfile.so
authz_host_module modules/mod_authz_host.so
authz_user_module modules/mod_authz_user.so
autoindex_module modules/mod_autoindex.so
dir_module modules/mod_dir.so
env_module modules/mod_env.so
filter_module modules/mod_filter.so
headers_module modules/mod_headers.so
include_module modules/mod_include.so
lbmethod_bybusyness_module modules/mod_lbmethod_bybusyness.so
lbmethod_byrequests_module modules/mod_lbmethod_byrequests.so
lbmethod_bytraffic_module modules/mod_lbmethod_bytraffic.so
lbmethod_heartbeat_module modules/mod_lbmethod_heartbeat.so
log_config_module modules/mod_log_config.so
mime_module modules/mod_mime.so
mpm_event_module modules/mod_mpm_event.so
negotiation_module modules/mod_negotiation.so
proxy_ajp_module modules/mod_proxy_ajp.so
proxy_balancer_module modules/mod_proxy_balancer.so
proxy_connect_module modules/mod_proxy_connect.so
proxy_express_module modules/mod_proxy_express.so
proxy_fcgi_module modules/mod_proxy_fcgi.so
proxy_ftp_module modules/mod_proxy_ftp.so
proxy_http_module modules/mod_proxy_http.so
proxy_module modules/mod_proxy.so
proxy_scgi_module modules/mod_proxy_scgi.so
proxy_wstunnel_module modules/mod_proxy_wstunnel.so
reqtimeout_module modules/mod_reqtimeout.so
setenvif_module modules/mod_setenvif.so
slotmem_shm_module modules/mod_slotmem_shm.so
status_module modules/mod_status.so
unixd_module modules/mod_unixd.so
userdir_module modules/mod_userdir.so
version_module modules/mod_version.so
Modules added per the wiki (using mysqld, ssl, and php):
Code: Select all
mpm_prefork_module modules/mod_mpm_prefork.so
php7_module modules/libphp7.so
socache_shmcb_module modules/mod_socache_shmcb.so
ssl_module modules/mod_ssl.so
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Re: Minimizing the number of modules for ownCloud on apache
Postby RealRancor » Sat Jul 02, 2016 12:49 am
disable one module after another and check if your oC installation is still working.
*gone*
darksky
Webserver: Apache
PHP version: 7.0.8
Postby darksky » Sat Jul 02, 2016 10:04 am
Was hoping for a faster method :)
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Sat Jul 02, 2016 10:32 am
Do you use a apache as a proxy? If not, you should be able to disable all proxy_* modules.
status_module is good for debugging but shouldn't be accessible on public.
userdir_module is not needed for owncloud.
darksky
Webserver: Apache
PHP version: 7.0.8
Postby darksky » Sat Jul 02, 2016 1:01 pm
Thanks for the tips. Disabling them doesn't seem to affect owncloud for my setup. The currently enabled lists are now as follows:
Code: Select all
Code: Select all
Return to “ownCloud Server 9.0”
