files:transfer-ownership not working correctly
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
Jillian1701
Postby Jillian1701 » Wed Jul 06, 2016 1:10 am
1. execute as root "./occ files:transfer-ownership User1 User2
The folder "Transferred from USER1 on TIME-STAMP" should be created, with all folders and files from USER1.
The folder "Transferred from USER1 on TIME-STAMP" exists, but is empty
Operating system: Ubuntu 14.04.1 LTS
Web server: Apache
PHP version: 5.5.9-1ubuntu4.17
ownCloud version (see ownCloud admin page): 9.0.3
ownCloud log (data/owncloud.log): Nothing in logs. No additional output from -vvv
Also please note, I cannot access the data directory from the command line. It is owned by www-data. Could this be the culprit?
jcal710
ownCloud version: 9.0.2
Webserver: Apache
PHP version: 5.5
Re: files:transfer-ownership not working correctly
Postby jcal710 » Wed Jul 20, 2016 1:47 pm
Did you try running the command as www-data?
from the owncloud folder on your server:
sudo -u www-data php occ files:transfer-ownership user1 user2
Return to “ownCloud Server 9.0”
