Owncloud HTTPS problem
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
mailo95
ownCloud version: 9.0.2
Webserver: Apache
Postby mailo95 » Mon Jul 18, 2016 5:49 pm
Please help us by providing the following info. Before posting please also check the pinned "Known issues" thread.
1.I read the owncloud manual
2.and i watched this video https://www.youtube.com/watch?v=fgOTvPSC-rg but no success
Access owncloud via https.
When ssl is disabled and try to connect via http redirects me to https://http//xxx.xxx.xxx.xxx/owncloud (same when i try only http://xxx.xxx.xxx.xxx without /owncloud)and when i thy via http://xxx.xxx.xxx.xxx/owncloud shows This site can’t be reached.
Before i try to enable the https when i type my ip opens apache page and then try my ip with /owncloud opens owncloud homepage but when i try with https show this side can't be reached.
Operating system:Linux Mint last updates
Web server:Apache
ownCloud version (see ownCloud admin page):
Updated from an older ownCloud or fresh install: Fresh
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Re: Owncloud HTTPS problem
Postby RealRancor » Mon Jul 18, 2016 8:29 pm
ownCloud itself is not providing any HTTPS so its the best to ask how to correctly setup your environment at either a Linux Minut forums or a community like http://www.apachelounge.com/
*gone*
mailo95
Webserver: Apache
Postby mailo95 » Tue Jul 19, 2016 2:22 pm
Why y cant help me here this is owncloud problem i just need to conf https redirection in owncloud ?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Jul 19, 2016 2:28 pm
You can't redirect to HTTPS in ownCloud. This needs to be configured within your webserver. And for such webserver specific topics its advised to ask at a community like described above.
The reason for this is easy: Most environments have different defaults, config files and setups so they have more knowledge about their specific environments as most people in the ownCloud forums.
*gone*
mcdaniels
Webserver: Apache
PHP version: 5.6.22
Postby mcdaniels » Tue Jul 19, 2016 3:14 pm
@TO: You can find a description of how it can be done here for example:
https://www.digitalocean.com/community/ ... untu-14-04
Return to “ownCloud Server 9.0”
