Nginx + php-fpm: "Call to a member function getLogger() on null"
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
theced7
ownCloud version: 6.0.2
Webserver: Apache
Database: PostgreSQL
PHP version: 5.4
Postby theced7 » Tue Jul 19, 2016 6:50 pm
I'm trying to get Owncloud up and running with Nginx after using it for quite some time with Apache. I've used the official config:
Code: Select all
upstream php-handler {
 #  server 127.0.0.1:9000;
    server unix:/var/run/php5-fpm.sock;
server {
  listen 80;
  server_name jumpingcrab.com;
  # enforce https
  return 301 https://$server_name$request_uri;
server {
  listen 443 ssl;
  ssl_certificate /etc/letsencrypt/live/jumpingcrab.com/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/jumpingcrab.com/privkey.pem;
  # Path to the root of your installation
  root /var/www/html;
  # set max upload size
  client_max_body_size 10G;
  fastcgi_buffers 64 4K;
  # Disable gzip to avoid the removal of the ETag header
  gzip off;
  # Uncomment if your server is build with the ngx_pagespeed module
  # This module is currently not supported.
  #pagespeed off;
  rewrite ^/caldav(.*)$ /remote.php/caldav$1 redirect;
  rewrite ^/carddav(.*)$ /remote.php/carddav$1 redirect;
  rewrite ^/webdav(.*)$ /remote.php/webdav$1 redirect;
  index index.php;
  error_page 403 /core/templates/403.php;
  error_page 404 /core/templates/404.php;
  location = /robots.txt {
    allow all;
    log_not_found off;
    access_log off;
  location ~ ^/(?:\.htaccess|data|config|db_structure\.xml|README){
    deny all;
  location / {
    # The following 2 rules are only needed with webfinger
    rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
    rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
    rewrite ^/.well-known/carddav /remote.php/carddav/ redirect;
    rewrite ^/.well-known/caldav /remote.php/caldav/ redirect;
    rewrite ^(/core/doc/[^\/]+/)$ $1/index.html;
    try_files $uri $uri/ =404;
  location ~ \.php(?:$|/) {
    fastcgi_split_path_info ^(.+\.php)(/.+)$;
    include fastcgi_params;
    fastcgi_param PATH_INFO $fastcgi_path_info;
    fastcgi_param HTTPS on;
    fastcgi_pass php-handler;
    fastcgi_intercept_errors on;
  # Adding the cache control header for js and css files
  # Make sure it is BELOW the location ~ \.php(?:$|/) { block
  location ~* \.(?:css|js)$ {
    add_header Cache-Control "public, max-age=7200";
    # Add headers to serve security related headers
    add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
    add_header X-Content-Type-Options nosniff;
    add_header X-Frame-Options "SAMEORIGIN";
    add_header X-XSS-Protection "1; mode=block";
    add_header X-Robots-Tag none;
    # Optional: Don't log access to assets
    access_log off;
  # Optional: Don't log access to other assets
  location ~* \.(?:jpg|jpeg|gif|bmp|ico|png|swf)$ {
    access_log off;
The owncloud directory sits in /var/www/html/owncloud, however, when I'm trying to open mydomain.com/owncloud all I get is a 500 error. Acessing a index.php with <?php phpinfo(); ?> works fine.
Code: Select all
tail /var/log/nginx/error.log
PHP message: PHP Fatal error:  Call to a member function getLogger() on null in /var/www/html/owncloud/lib/public/util.php on line 154" while reading response header from upstream, client: MYIP, server: jumpingcrab.com, request: "GET /owncloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "jumpingcrab.com"
Any idea what causes this issue? Do I need to do some configuration in php5-fpm?
Operating system: Debian 8.5
Web server: Nginx
PHP version: 5.6
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Nginx + php-fpm: "Call to a member function getLogger() on null"
Postby RealRancor » Tue Jul 19, 2016 10:09 pm
try the one for oC 9 which is different then the one you're using:
https://doc.owncloud.org/server/9.0/adm ... ud_9x.html
If you still get the same error you can have a search for the error at the bugtracker:
https://github.com/owncloud/core/issues
where you might get additional infos about it.
*gone*
theced7
Webserver: Apache
PHP version: 5.4
Postby theced7 » Tue Jul 19, 2016 11:03 pm
Sadly, this doesn't change anything. :(
Any further ideas? I'm sure I'm not the only one running owncloud on nginx?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Jul 20, 2016 9:28 am
RealRancor wrote:If you still get the same error you can have a search for the error at the bugtracker:
*gone*
Return to “ownCloud Server 9.0”
