debian update after a manual install - possible to retrieve data?
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
ownerfan
ownCloud version: 9.0.2
Webserver: Apache
PHP version: 5.6.22
Postby ownerfan » Wed Jul 20, 2016 6:18 am
Please help us by providing the following info. Before posting please also check the pinned "Known issues" thread.
1. Installed ownCloud 9 using the installer setup-owncloud.php in /var/www/owncloud
2.Applied an ownCloud debian update from the Update Manager because I forgot I installed it manually.
3.
My ownCloud does not work. When I enter my localhost url for ownCloud, it's blank instead of getting the login screen.
Operating system: Linux Mint Debian v2.
Web server: apache 2.4
Database: MySQL 5.5.49
PHP version: 5.56.23
ownCloud version (see ownCloud admin page): 9
Updated from an older ownCloud or fresh install: No
Is it possible for me to retrieve my data that I have stored on a separate drive if I re-install ownCloud again? I didn't backup my config folder or mysql
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Re: debian update after a manual install - possible to retrieve data?
Postby RealRancor » Wed Jul 20, 2016 9:32 am
a white page mostly means an internal server error. How to get additional info about that is available here:
viewtopic.php?f=17&t=8315
*gone*
ownerfan
Webserver: Apache
PHP version: 5.6.22
Postby ownerfan » Wed Jul 20, 2016 1:23 pm
Thanks RealRancor.
In the meantime, I checked the owncloud.log file in my data directory and this is the output:
{"reqId":"Q+9RXLWdNi835+xoPSQ7","remoteAddr":"127.0.0.1","app":"PHP","message":"Cannot redeclare class OC_L10N at \/var\/www\/owncloud\/lib\/private\/l10n.php#43","level":3,"time":"2016-07-20T04:05:06+00:00"}
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Jul 20, 2016 1:27 pm
this means that you have some old code laying around like seen here for example:
viewtopic.php?t=34154
This hint here:
https://github.com/owncloud/core/issues ... -233917021
might fix the issue that you have mixed a manual package with repository packages.
*gone*
ownerfan
Webserver: Apache
PHP version: 5.6.22
Postby ownerfan » Wed Jul 20, 2016 3:52 pm
Yes, the mixed manual and repository installation must have caused an issue. I just re-installed owncloud using the original downloaded zip file I kept and restored my data and config directories. Luckily the repository upgrade didn't change my database and it only changed my config file by changing maintenance => false to maintenance => true.
Now, I'd like to purge the repository owncloud but I'm concerned I'll have issues again and have to re-install. Anyone try that? What happened?
Return to “ownCloud Server 9.0”
