Scanning external storage ONLY
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
Mophus
Beginner
ownCloud version: 9.0.0
Webserver: Apache
PHP version: 5.4.16
Postby Mophus » Wed Jul 20, 2016 9:52 am
How do I set the `--path` parameter in order to scan an external storage (for a specific user ${OC_USER})?
These will update all files of ${OC_USER}:
Code: Select all
sudo -u apache ${OC_ROOT}/occ files:scan ${OC_USER}
sudo -u apache ${OC_ROOT}/occ files:scan --path="${OC_USER}"
This will update only the internal files of ${OC_USER}:
Code: Select all
sudo -u apache ${OC_ROOT}/occ files:scan --path="${OC_USER}/files"
This doesn't work:
Code: Select all
sudo -u apache ${OC_ROOT}/occ files:scan --path="/path/to/external/files" ${OC_USER}
Code: Select all
Unknown user 1 var
Return to “ownCloud Server 9.0”
