Sync Problems: Errors written to synced files
You found a bug or you're missing a major feature? Just ask and discuss
chartan
ownCloud version: 5.0.10
Webserver: Apache
Postby chartan » Fri Sep 06, 2013 7:46 pm
Hi all
I found that I have massive problems with the client sync (with OC 1.4 on mac). Tried it with the admin user and a "dummy" user. it is always the same. So the questions are:
1) What do those errors mean and how can I solve them?
2) Why are the errors written to the synced files? Is this normal behavior?
Here is a screenshot:
Seems the image will get cut off. Here is the full screen:
http://www.magicmac.ch/voila_snapz/owncloudError060913.png
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Sync Problems: Errors written to synced files
Postby RealRancor » Fri Sep 06, 2013 9:54 pm
errors never should be written to the synced file so i think you should report this to the devs at the bugtracker. Start your sync client with logging enabled like described here:
viewtopic.php?f=17&t=6526
and report a new issue here:
https://github.com/owncloud/mirall/issues
with the collected logfile using the issue template available here:
https://github.com/owncloud/mirall/blob ... emplate.md
*gone*
chartan
Webserver: Apache
Postby chartan » Sat Sep 07, 2013 12:50 pm
Thanks, I'll do that immediately and post a new report. Maybe I can already find something strange in the logfile myself.
chartan
Webserver: Apache
Postby chartan » Sat Sep 07, 2013 2:44 pm
Probably I have found the problem: owncloud sync doesn't seem to play well with gzip compression (mod_deflate). I have disabled it on the owncloud directory and so far it syncs fine.
chartan
Webserver: Apache
Postby chartan » Sat Sep 07, 2013 6:17 pm
OK, sync finished without any error, so as far as I can tell, owncloud doesn't work properly with mod_deflate enabled.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sun Sep 08, 2013 2:09 pm
thanks for this info. Just added the module to the list of modules which have problems with OC:
viewtopic.php?f=17&t=7240
*gone*
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Mon Sep 09, 2013 9:42 pm
i've reported this to the bugtracker. A dev has replied that mod_deflate is not supported at the moment:
https://github.com/owncloud/mirall/issu ... t-24106860
*gone*
Return to “Discuss possible bugs & feature requests”
