External storage is not visible
You found a bug or you're missing a major feature? Just ask and discuss
realriot
Postby realriot » Wed Jun 20, 2012 2:02 pm
I've configured an external storage link within "config/mount.php" and activated the app within the settings menu...
mount.php
Code: Select all
<?php
return array(
    'group'=>array(
        'admin'=>array(
            '/nasfs/media'=>array('class'=>'OC_Filestorage_Local','options'=>array('datadir'=>'/www/htdocs/owncloud/foo'))
I've expected a link/directory within "files" section which is called "nasfs/media"... But nothing appears. Is there something additionally to configure? I'm using V4.0.2
Thanks in advance
Sascha
realriot
Re: External storage is not visible
Postby realriot » Fri Jun 22, 2012 8:21 pm
No hint? Anyone?
MTGap
Developer
Postby MTGap » Fri Jun 22, 2012 9:24 pm
You didn't configure it correctly. It should be /$user/files/nasfs for the mountpoint.
You may need to create a folder in ownCloud to get access to the mountpoint.
Return to “Discuss possible bugs & feature requests”
