Poor DB performance, no indexes. Suggested Indexes
You found a bug or you're missing a major feature? Just ask and discuss
Van
Beginner
ownCloud version: 4.5.3
Postby Van » Thu Sep 13, 2012 7:11 pm
ownCloud: 4.5b3a
MySQL: 5.5.27
How come not all the database tables have indexes?
Reported here: http://bugs.owncloud.org/thebuggenie/ow ... es/oc-1736
Van
Beginner
Re: Database tables have no indexes?
Postby Van » Thu Sep 13, 2012 7:26 pm
Based on our observation, we did the following:
Code: Select all
ALTER TABLE `owncloud`.`oc_properties`
  ADD  INDEX `oc_properties_idx1` (`userid`),
  ADD  INDEX `oc_properties_idx2` (`propertyname`);
Code: Select all
ALTER TABLE `owncloud`.`oc_locks`
  ADD  INDEX `oc_locks_idx1` (`userid`);
ownCloud 4.5, Ubuntu 12.04, apache, MySQL 5.5.x, VirtualBox, glusterFS.
We have abandoned ownCloud. Read why here:
http://forum.owncloud.org/viewtopic.php?f=3&t=4582
Van
Beginner
Postby Van » Thu Sep 13, 2012 7:31 pm
Also did this:
Code: Select all
ALTER TABLE `owncloud`.`oc_fscache`
  ADD INDEX `path_index` (`path`);
Van
Beginner
Re: Database tables have no indexes? - Suggested Indexes
Postby Van » Fri Sep 14, 2012 12:03 am
Code: Select all
ALTER TABLE `owncloud`.`oc_preferences`
  ADD  INDEX `oc_preferences_idx1` (`userid`),
  ADD  INDEX `oc_preferences_idx2` (`appid`, `configkey`);
Code: Select all
ALTER TABLE `owncloud`.`oc_appconfig`
  ADD  INDEX `oc_appconfig_idx1` (`appid`, `configkey`);
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Re: Poor DB performance, no indexes. Suggested Indexes
Postby RandolphCarter » Fri Sep 14, 2012 10:23 am
@Van: Did you check if theses indexes help performance? Preferably by testing with a large owncloud installation ;)? Would be cool to see performance improvements...
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Sep 14, 2012 10:26 am
thanks for sharing this. I didn't noticed that some indexes where missing in the database.
@RandolphCarter
Yes that would be a nice info.
@Van
Did you started a feature request @ http://bugs.owncloud.org/thebuggenie/ ?
*gone*
Van
Beginner
Postby Van » Fri Sep 14, 2012 2:06 pm
We are currently testing ownCloud for a possible rollout in our company. We just currently expanded the test to 50 users (eventually will be 500+). The biggest drawback right now is the _conflict- file issue. If it isn't addressed soon then it will probably kill the project.
We are a large MySQL shop and we have many tools for monitoring performance. The best tool we use is MONyog for monitoring MySQL servers. We are very familiar with MySQL performance issues. By most accounts a FULL TABLE scan is bad news and that is exactly what was happening.
What we noticed is the tables above get references quite frequently when sync'ing files. Review this 15 minute sampling (copy-paste into a text editor to see it better) of the top 20 queries:
Code: Select all
Total   Avg   Max   Sent   Examined   Lock time   Count   Query Occurrence( % )   First Seen   Last Seen   User@Host   Query
44.082   0.027   0.06   0   17.964K   0   1623   15.459    Sep  13, 12 13:05:19    Sep  13, 12 13:17:33   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_properties` WHERE `userid` = ? AND `propertypath` = ?;
03:02.913   0.187   5.202   0   97.062K   0   977   9.306    Sep  13, 12 13:05:19    Sep  13, 12 13:29:47   owncloud[owncloud] @ localhost []   SELECT `path` FROM `oc_fscache` WHERE `path` LIKE ?;
29.274   0.037   0.278   0   17.869K   0   795   7.572    Sep  13, 12 13:05:21    Sep  13, 12 13:17:33   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?,?,?,?,?);
28.494   0.036   0.265   0   17.868K   0   784   7.467    Sep  13, 12 13:05:21    Sep  13, 12 13:17:33   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?,?,?,?);
20.257   0.036   0.278   0   17.886K   0   564   5.372    Sep  13, 12 13:05:19    Sep  13, 12 13:17:32   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?,?,?,?,?,?);
15.92   0.029   0.215   0   17.876K   0   541   5.153    Sep  13, 12 13:05:19    Sep  13, 12 13:17:30   owncloud[owncloud] @ localhost []   UPDATE `oc_properties` SET `propertypath` = ? WHERE `userid` = ? AND `propertypath` = ?;
0.215   0   0.001   0   0   0   462   4.4    Sep  13, 12 13:05:22    Sep  13, 12 13:23:39   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`uri` LIKE ?));
0.216   0   0.002   0   0   0   442   4.21    Sep  13, 12 13:05:20    Sep  13, 12 13:23:37   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`uri` LIKE ?));
14.931   0.041   0.342   0   17.887K   0   364   3.467    Sep  13, 12 13:05:14    Sep  13, 12 13:17:28   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?,?,?,?,?,?,?);
10.267   0.033   0.114   0   17.873K   0   315   3    Sep  13, 12 13:05:23    Sep  13, 12 13:17:30   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?,?,?);
0.167   0.001   0.001   0   0   0   306   2.915    Sep  13, 12 13:05:23    Sep  13, 12 13:23:32   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?));
0.186   0.001   0.026   0   0   0   280   2.667    Sep  13, 12 13:05:13    Sep  13, 12 13:23:39   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?));
0.13   0.001   0.002   0   0   0   246   2.343    Sep  13, 12 13:05:28    Sep  13, 12 13:23:19   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`uri` LIKE ?));
0.132   0.001   0.001   0   0   0   240   2.286    Sep  13, 12 13:05:13    Sep  13, 12 13:23:33   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`uri` LIKE ?));
0.099   0.001   0.002   0   0   0   158   1.505    Sep  13, 12 13:05:20    Sep  13, 12 13:23:35   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?));
3.472   0.022   0.041   1   18.165K   0   158   1.505    Sep  13, 12 13:05:29    Sep  13, 12 13:06:42   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_properties` WHERE `userid` = ? AND `propertypath` IN (?);
0.098   0.001   0.002   0   0   0   157   1.495    Sep  13, 12 13:05:29    Sep  13, 12 13:23:20   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?) OR (`depth` != ? AND `uri` = ?));
3.137   0.023   0.044   2   18.158K   0   136   1.295    Sep  13, 12 13:05:29    Sep  13, 12 13:06:42   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_properties` WHERE `userid` = ? AND `propertypath` IN (?,?);
3.415   0.031   0.05   0   17.877K   0   111   1.057    Sep  13, 12 13:05:20    Sep  13, 12 13:17:27   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?,?,?,?,?,?,?,?);
2.025   0.024   0.046   3   18.154K   0   85   0.81    Sep  13, 12 13:05:36    Sep  13, 12 13:06:42   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_properties` WHERE `userid` = ? AND `propertypath` IN (?,?,?);
2.172   0.032   0.072   0   18.049K   0   68   0.648    Sep  13, 12 13:05:27    Sep  13, 12 13:17:15   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?);
2.154   0.037   0.146   0   17.885K   0   58   0.552    Sep  13, 12 13:05:49    Sep  13, 12 13:17:29   owncloud[owncloud] @ localhost []   DELETE FROM `oc_properties` WHERE `userid` = ? AND `propertyname` = ? AND `propertypath` IN (?,?,?,?);
0.022   0   0.001   0   0   0   48   0.457    Sep  13, 12 13:05:27    Sep  13, 12 13:06:51   owncloud[owncloud] @ localhost []   SELECT * FROM `oc_locks` WHERE `userid` = ? AND (`created` + `timeout`) > ? AND (( `uri` = ?) OR (`depth` != ? AND `uri` = ?));
The server is performing full table scans. oc_properties being the most guilty at 1623 hits followed by oc_fscache of 977. From what we can tell, these tables are hit for every file that is being sync'd with ownCloud.
So, Yes, we noticed a significant MySQL performance improvement when we added these indexes. I can just imagine the MySQL performance catastrophee a service provider of 1,000+ or even 10,000+ users must be having. This is a major development oversight on the part of the developers. I suspect the developers have no clue how to properly design or use a relational database. But, most developers don't so this is nothing new.
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Sep 14, 2012 2:18 pm
Wow, thanks for this great research and the details you provide. I think this should definitely be added as a bug to the bugtracker so the Devs notice it.
*gone*
Van
Beginner
Postby Van » Fri Sep 14, 2012 2:35 pm
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Mon Sep 17, 2012 1:17 pm
Thanks, voted an +1 for this report. 8-)
*gone*
Return to “Discuss possible bugs & feature requests”
