OwnCloud Release 5.0.6
Everything you need to know
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue May 14, 2013 7:14 pm
Changelog:
  • SECURITY: SQL Injection (oC-SA-2013-019)
  • SECURITY: Multiple directory traversals (oC-SA-2013-020)
  • SECURITY: Multiple XSS vulnerabilities (oC-SA-2013-021)
  • SECURITY: Open redirector (oC-SA-2013-022)
  • SECURITY: Password autocompletion (oC-SA-2013-023)
  • SECURITY: Privilege escalation in the calendar application (oC-SA-2013-024)
  • SECURITY: Privilege escalation and CSRF in the API (oC-SA-2013-025)
  • SECURITY: Incomplete blacklist vulnerability (oC-SA-2013-026)
  • SECURITY: Information disclosure: CSRF token + username (oC-SA-2013-027)
  • Fix renaming of shared files
  • Fix UUID handling with LDAP
  • Fix several undelete files issues
  • Fix LDAP cachekey handling
  • Several OCS API fixes
  • Dropbox mounting fixes
  • Remove ldap group name restrictions
  • Fix fetching of the userlist with multiple user backends
  • Turn off password autocompletion
  • Translation fixes of the Shared folder
  • Fix the fileactions order for filetypes
  • Allow to ship a default theme
  • Disallow URLs containing “@”
  • Smaller layout improvemens
  • Log an upgrade warning
  • Log a trash bin cleanup message
  • Improved quota calculation
  • Allow to set Quota to zero
  • Fix performance regression for uploading of big files
  • Several Calendar fixes
  • Use displaynames in contacts
  • Check for existing address books during migrate->import
  • Texteditor fixes
  • Increase the SQLite database timeout
  • Order images in Gallery
Download: http://download.owncloud.org/community/ ... .6.tar.bz2
MD5: http://download.owncloud.org/community/ ... ar.bz2.md5
*gone*
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Re: OwnCloud Release 5.0.6
Postby RealRancor » Tue May 14, 2013 7:20 pm
Additional some informations from the mailinglist:
https://mail.kde.org/pipermail/owncloud ... 09071.html
If you have a custom theme running you have to disable this in your config.php and make sure you update your theme with the template changes in OC 5.0.6:
https://mail.kde.org/pipermail/owncloud ... 09073.html
*gone*
Return to “Announcements”
Users browsing this forum: No registered users and 5 guests
