Owncloud server release 9.0.2, 8.2.4, 8.1.7, 8.0.12 and 7.0.14
Everything you need to know
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Fri May 06, 2016 11:11 pm
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: Owncloud server release 9.0.2, 8.2.4, 8.1.7, 8.0.12 and 7.0.14
Postby RealRancor » Sat May 07, 2016 10:30 am
Hi all,
We've made available maintenance releases for all our supported releases. It
is highly recommended to upgrade to benefit from the security and stability
improvements. Learn more at https://owncloud.org/?p=9951
Our iOS client was also updated: https://owncloud.org/blog/ios-client-update/
Last but not least, the ImageTragick security vulnerability can affect
ownCloud installations. We strongly recommend to check your setup and take
action if you need to:
https://owncloud.org/blog/imagetragick- ... oud-users/
Thanks and take care,
http://owncloud.10557.n7.nabble.com/new ... 17226.html
*gone*
Return to “Announcements”
Users browsing this forum: No registered users and 5 guests
