Malformed Server Configuration - Android client
Ask all your questions on mobile clients. Please read the Support Forum Rules
Strathy
Postby Strathy » Wed Aug 07, 2013 2:53 am
I'm able to use ownCloud on my desktop, but when I attempt to login with my Android device, I get 'Malformed Server Configuration'. Seems to be something to do with certificates? I don't know anything about this stuff - any help would be appreciated.
Thanks!
rakekniven
Inventory
ownCloud version: 9.0.1
Webserver: Apache
OS: Linux Hosting Package
PHP version: 5.6.x
Contact:
Re: Malformed Server Configuration - Android client
Postby rakekniven » Mon Aug 26, 2013 3:28 pm
Strathy wrote: Seems to be something to do with certificates?
Why do you think?
Have you checked server log file?
Webserver logs?
ownCloud is not only about files. There is so much more. Explore the apps to extend your ownCloud.
petershea
ownCloud version: 5.0.10
Webserver: Apache
PHP version: 5.4
Postby petershea » Fri Sep 20, 2013 6:34 pm
I had the same problem.
In my case, it was because I had set up a forwarded DNS entry to the server for convenience (i.e. http://cloud.xxx.com pointing to http://my.internal.address:port) . It turns out that the app can't deal with that.
If I use the direct address (http://my.internal.address:port), it all works fine.
Maybe you're experiencing something similar.
Peter.
Orris
ownCloud version: 5.0.11
Webserver: nginx
Postby Orris » Mon Oct 14, 2013 4:13 pm
I too have had this problem but mine was to do with the status.php showing installed as false.
https://yourowncloudsever.com/status.php
Will show something like
Code: Select all
 {"installed":"false","version":"5.0.20","versionstring":"5.0.11","edition":""}
I fixed this by editing config.php from:
Code: Select all
<?php
$CONFIG = array (
  'installed' => 'true',
to
Code: Select all
<?php
$CONFIG = array (
  'installed' => '1',
status.php showed installed and true and android app worked straight away.
Hope that helps
Sphinx
Teacher
ownCloud version: 5.0.14a
Webserver: Apache
PHP version: 5.4
Contact:
Postby Sphinx » Mon Oct 14, 2013 5:54 pm
Code: Select all
<?php
$CONFIG = array (
Something very, very wrong there in your php installation.
Return to “ownCloud mobile sync clients”
