CSync failed to create a lock file - Linux problem
hurior
Beginner
Postby hurior » Thu Apr 19, 2012 1:19 pm
I have a problem with the sync, I've mount my owncloud under openSuSE 12.1 + KDE (server and client) and when I add a folder to sync it says:
Code: Select all
and then stops sync.
If I start owncloud from a terminal it says that:
Code: Select all
>===================================== sync started for  "2012"
==== added CSync exclude List:  "/etc/exclude.lst"
[stderr] 20120419 11:06:51.726 ERROR    csync.lock- Aborting, another synchronization process is running.
 #### ERROR String emitted:  "CSync failed to create a lock file."
CSync run took  69  Milliseconds
  ** error Strings:  ("CSync failed to create a lock file.")
    * owncloud csync thread finished with error
    * event notification  enabled
OO folder slotSyncFinished: result:  4  local:  false
Status:  4
Sync state changed for folder  "2012" :  false
*  "2012" Poll timer enabled with  16520 milliseconds
<===================================== sync finsihed for  "2012"
My server details:
Environment: Home Server - Opensuse 12.1
Server: Apache
Database: Mysql
Client: owncloud 3.0.2 (it works fine with konqueror)
OC-Version: 3.0.2
PHP-Version: 5.3.8
Any help?
Thanks a lot.
Escubar
ownCloud Inc. Representative
Re: CSync failed to create a lock file - Linux problem
Postby Escubar » Thu Apr 19, 2012 5:01 pm
The ownCloud application was not properly shut down the last time you used it.
I had to delete the lock file from .csync in my home directory and it worked.
Just rm lock should work for you as well.
Discussing an improvement with the developer already.
hurior
Beginner
Postby hurior » Thu Apr 19, 2012 8:51 pm
Hi, this helpme almost... Now I can sync, but only folders...
Then it says
Code: Select all
CSync Update failed.
and no more...
Any ideas?
Thanks a lot
hurior
Beginner
Postby hurior » Fri Apr 20, 2012 8:42 pm
Hi again, I can sync some folders now, but others doesn't work, are some limitation of size of number or subfolders to sync? It's the only thing that I can understand...
When the sync stops it says
Code: Select all
Any help? Please I want to use it under my job folders, and I can't now... :(
Thanks a lot.
soletan
Postby soletan » Sat May 26, 2012 10:32 pm
Same problem here with Mac OS X Client version 1.02 under Lion (10.7.4). Since this is the first time it's running right after installation it can't be due to improper previous shutdown. At least I hadn't any chance to consciously restart anything.
Business partner told me he couldn't even start it under Snow Leopard (10.6).
What's wrong actually?
Best Regards.
web-vision
Postby web-vision » Tue May 29, 2012 9:47 am
we had the same problem here while running Mac OSX Lion (10.7.4) with network accounts for users.
It seems that .csync was created on the network share, but ownCloud couldn't write into it.
I solved it by stopping sync (just to avoid unwanted things). Then I opened up terminal and went to my user folder:
Code: Select all
cd ~
pwd
My user folder was located here: /Network/Servers/server.web-vision.lan/Shared/bhinzer
After that I deleted the existing .csync folder:
Code: Select all
sudo rm -Rf .csync
Usually you need to enter the administrators password to delete the folder.
Now I changed to a local folder I usually use for avoiding similar issues with other applications (like dropbox or firefox) and created a new .csync folder:
Code: Select all
cd /Users/Shared/bhinzer
mkdir .csync
If you don't have such a local user folder you can create .csync in one go from terminal with the following command:
Code: Select all
mkdir -p /Users/Shared/username/.csync
Finally I went back to my original user folder on the network shared and made a symlink to my new local folder:
Code: Select all
cd ~
ln -s /Users/Shared/bhinzer/.csync
After that I resumed sync and it works like charm since then.
Regards,
Boris
soletan
Postby soletan » Sat Jun 02, 2012 6:07 pm
@web-vision: Thanks for your reply. I tried your solution, though it didn't apply here at all. My user's folder is already under /Users, it contains lots of hidden subfolders but no .csync to remove, finally it would be okay to have such a folder there usually not requiring any administrative privileges as this is not a network share as it seems to be in your case.
Finally, if your solution would apply it still wouldn't be a solution to me. I'm a software developer myself and thus quite used to work with CLIs and BSD/Linux/Unix-filesystems. However, I'd going to promote ownCloud as a service to my customers and I can't expect them to open up Terminal just to fix a mislocated .csync-folder ...
Will try to build the client from source next trying to figure out what else might be causing this issue.
soletan
Postby soletan » Sat Jun 02, 2012 6:27 pm
@web-vision: me again. Though my case wasn't equivalent to your's it was related to it somehow. For some reason my own user folder was owned by a different user not existing anymore. I expect this to be related to transferring my current Mac OS installation from a different device using Apple's migration wizards, failing to properly fix file permissions ... now ownCloud succeeds to create the lock though fails to sync nevertheless for some different reason ...
random1234
Beginner
Postby random1234 » Mon Jun 04, 2012 9:06 am
I also have this issue. If I delete the lock file or even the whole .csync folder owncloud syncs but soon after reports "CSync failed to create a lock file." again and no sync is performed. Lock file or .csync folder is recreated immediately so owncloud can write to it. I also tried changing rights to 777 for .csync so there shouldn't be any write issues for owncloud.
I'm also getting conflicting files on recent files from other machines. The issue started now after the lock file issue so I'm guessing they are related.
kmacc
Postby kmacc » Tue Jun 05, 2012 3:37 am
I get this too. I've got the client running in Ubuntu 12.04. I just need to remove the lock file and that fixes it but sometime later (possibly after my laptop has gone to sleep?) it re-occurrs.
Users browsing this forum: No registered users and 5 guests
