how to enable webdav access [SOLVED]
Ask all your questions regarding OC 7.x Please read the Support Forum Rules
ownCloud 7.x will be end of life soon. See maintenance and release schedule for more details.
Time to upgrade!
lk2014
ownCloud version: 7.0.3
Webserver: Apache
Postby lk2014 » Thu Dec 11, 2014 5:51 pm
I have just succesfully installed owncloud 7.0.4 on an Ubuntu 14.04 docker container.
The problem is that I have no idea how to access the server via Webdav.
I tried this link with no success:
davs://www.eidosoft.com:10443/owncloud/ ... php/webdav
Here is the configuration for apache web server (001-owncloud.conf):
Code: Select all
<Directory /var/www/owncloud>
    Options Indexes FollowSymLinks MultiViews
    AllowOverride All
    Require all granted
    Dav Off
    Satisfy Any
</Directory>
<VirtualHost *:443>
  DocumentRoot /var/www/owncloud
    AllowOverride All
    Require all granted
    Dav Off
    Satisfy Any
  </Directory>
  SSLEngine on
  SSLCertificateFile /etc/apache2/ssl/server.crt
  SSLCertificateKeyFile /etc/apache2/ssl/server.key
</VirtualHost>
Any ideas about how to activate the WebDav support?
LK
starkruzr
Beginner
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.12
Re: how to enable webdav access
Postby starkruzr » Thu Dec 11, 2014 6:21 pm
Why do you have "dav off" in your configuration?
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Thu Dec 11, 2014 6:29 pm
That's ok, owncloud doesn't use the webserver's webdav support, it brings it owns (see example-config in the docs).
Can you try to access webdav via your browser:
https://www.eidosoft.com:10443/owncloud/ ... php/webdav
Check your logfiles, if there are any suspicious entries.
starkruzr
Beginner
Webserver: Apache
PHP version: 5.5.12
Postby starkruzr » Thu Dec 11, 2014 6:44 pm
tflidd wrote:That's ok, owncloud doesn't use the webserver's webdav support, it brings it owns (see example-config in the docs).
I think something strange is going on with your links. Hang on, lemme take a look at this.
Also, when I try to connect to https://www.eidosoft.com:10443/owncloud ... php/webdav, it sees the DAV share correctly and tries to authenticate me.
lk2014
Webserver: Apache
Postby lk2014 » Thu Dec 11, 2014 8:44 pm
An owncloud page appears with the message: "File not found - The specified document has not been found on the server. You can click here to return to ownCloud."
On the log there is nothing. I noticed that on the log I can see the attempt to access from Krusader using webdav protocol.
LK
lk2014
Webserver: Apache
Postby lk2014 » Thu Dec 11, 2014 8:47 pm
??? If I try that url I get an owncloud page telling "File not found".
Are you sure you can try to authenticate?
LK
tflidd
Forum Moderator
Webserver: Apache
Postby tflidd » Fri Dec 12, 2014 9:28 am
Can you try this link:
https://www.eidosoft.com:10443/remote.php/webdav
Your installation seems not to be in a subfolder owncloud (if you prefer it with owncloud in the URL, you have to change the DocumentRoot to /var/www)
lk2014
Webserver: Apache
Postby lk2014 » Fri Dec 12, 2014 6:38 pm
tflidd wrote:Can you try this link:
You are right. I changed the configuration and now it works.
Just a thing: the root of apache now is accessible to everyone (everyone can list the content of that direcotry). Is it possible to disable the access to that directory?
LK
starkruzr
Beginner
Webserver: Apache
PHP version: 5.5.12
Postby starkruzr » Fri Dec 12, 2014 8:40 pm
LK
You could turn off Apache directory browsing. Google that and you'll almost certainly get it immediately.
lk2014
Webserver: Apache
Postby lk2014 » Sat Dec 13, 2014 1:46 pm
I googled a lot but I'm still not able to disable web server to browse the root directory.
I tried -Index option and the web server didn't start, with the None option the server starts but the root directory is still available.
I'm starting to think that I cannot do this configuration inside a sites-available/mysite.conf file.
LK
Return to “ownCloud Community Edition 7.x”
Users browsing this forum: No registered users and 4 guests
