Remember login
mase76
Webserver: Apache
Database: PostgreSQL
Remember login
Postby mase76 » Tue Feb 10, 2015 6:02 pm
Hi!
In the past I could set to remenber my login in the login page.
Now this function isn't available any more. This was useful when
docking news and bookmarks to the browsers panel.
myitbrain
Starter
ownCloud version: 7.0.3
Webserver: proprietary
OS: Linux Hosting Package
PHP version: 5
Re: Remember login
Postby myitbrain » Wed Feb 11, 2015 6:50 am
I'd recommend cleaning the Browser cache to avoid computer issues. If the problems is there after that go to the admin session and check the log to see if you have any error in your installation and post it here.
Good luck! :idea:
utahbmxer
Beginner
ownCloud version: 5.0.12
Webserver: Apache
PHP version: 5.3
Re: Remember login
Postby utahbmxer » Thu Feb 12, 2015 3:07 am
My option to remember the login is missing from the login screen as well. Now when I use the "add to owncloud" bookmark option from my browser I have to sign in each time.
The stable build I have on one of my other servers from a few days ago has the checkbox though, odd. That server was never upgraded from 7, it was just an install I was using to watch the daily builds for version 8.
I've combed through the admin & users section looking for an option to enable. I thought I remember seeing a feature that mentioned the ability to turn this on/off. What am I missing, is there an app for this or is it part of the core?
Thanks,
Nate
utahbmxer
Beginner
Webserver: Apache
PHP version: 5.3
Re: Remember login
Postby utahbmxer » Thu Feb 12, 2015 7:54 am
Apparently, certain apps disable this feature. In my case it was the files_external app. I edited appinfo/info.xml to read:
Code: Select all
<rememberlogin>true</rememberlogin>
Not sure if there are any side effects, or if this will get wiped out when the app is updated, but it's working for me.
Found this here: https://github.com/owncloud/documentation/issues/782
mase76
Webserver: Apache
Re: Remember login
Postby mase76 » Fri Feb 13, 2015 5:05 pm
Yes, that brought back the expected functionality.
But as you said, will this survive an app update?
