How to access ownCloud outside of LAN?
cre8ive65
Postby cre8ive65 » Thu May 31, 2012 6:30 am
Hi
This may be a silly question, but how do i access my ownCloud outside of my LAN?
Right now, my address is "http://192.168.1.70/owncloud/", but that only works in my LAN.
Do I need to port forward so I can access it via "http://MYGLOBALIP/owncloud/" if so which port?
Or do I need to make a VPN?
I need Both web, Linux, and Windows client access outside of my LAN
DuNdReT
Re: How to access ownCloud outside of LAN?
Postby DuNdReT » Thu May 31, 2012 1:36 pm
You need to portforward port 80 to your internal ip-addess, in this case 192.168.1.70
cre8ive65
Postby cre8ive65 » Sat Jun 02, 2012 11:12 pm
I did that, and it kind of worked.
Now I can access it at MY.GLOBAL.IP/owncloud from INSIDE my LAN, but outside my LAN MY.GLOBAL.IP/owncloud refuses to load, it says its loading in the prgress bar but it never gets more than about 2%, which is progress from a "404 error" that I got when I did not forward that port.
This computer running owncloud is also running a minecraft server on port 25565, so thinking they might interfere, I set this server as a DMZ host in my router, which supposedly allows ALL traffic, but to no avail. I also tried shutting off the minecraft server software but that did nothing either.
Any ideas as to how to fix this?
Nidoh
Postby Nidoh » Mon Jun 04, 2012 9:17 pm
Hi, 2 things i can think of to check:
1) Check you are using correct external IP (what is my ip . com or similar)
2) Check that your router is forwarding the port 80 traffic correctly. (more likely problem)
Good luck
cre8ive65
Postby cre8ive65 » Tue Jun 05, 2012 2:04 am
Yes yes I did all of that, I'm beginning to think this is a problem with iptables, by default it will refuse inbound on port 80 and 443, but i dont know how to open up access to port 80 with iptables. (Im using Lubuntu 12.04 for the server's OS)
cre8ive65
Postby cre8ive65 » Tue Jun 05, 2012 2:39 am
Well i just uninstalled iptables and that doesnt seem to be the issue, could it be my ISP blocking port 80 inbound?
Everything is open, am i missing a config file or something? Im baffled, Ill call my ISP and see what they have to say about port 80 or 443 inbound
Nidoh
Postby Nidoh » Tue Jun 05, 2012 12:08 pm
If you already have a working port 25565, you could always shutdown minecraft and restart owncloud on that port. If it works, you have a network issue, if not you have a owncloud issue.
GL :)
vamshinath
ownCloud version: 8.0.9
Webserver: Apache
PHP version: 5
Postby vamshinath » Tue Dec 22, 2015 5:58 pm
hi friends, i am also facing same problem like cre8ive65's please help me......i can access own cloud using http://publicIp/owncloud through my network ...but from netcafe i cannot. please help me
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Dec 22, 2015 7:11 pm
Please create a new thread for your issue and provide more info about your environment / setup.
As this is very likely also not an ownCloud issue but just an environment issue you might want to first read into topics like NAT and Port Forwarding to get the basic knowledge how to make your system available at your internet.
*gone*
vamshinath
Webserver: Apache
PHP version: 5
Postby vamshinath » Tue Dec 22, 2015 7:27 pm
RealRancor thank you, why don't you describe the steps to be followed for making it available online..........my problem is I can use owncloud by by http://192.168.0.XXX/owncloud but when i use http://publicIP/owncloud (publicIP .....from what'smyip website )...i am getting Error 404:Not Found. i have configured port forwarding in my router .please help me
