ownCloud 8.2.x (known issues, faq and upgrade problems)
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Sat Oct 31, 2015 11:12 am
Blogpost about upgrading: https://owncloud.org/blog/upgrading-to- ... erver-8-2/
General changes in this release: https://doc.owncloud.org/server/8.2/adm ... notes.html
Another blogpost how to do a correct upgrade: http://blog.jospoortvliet.com/2016/01/h ... -skip.html
Please read those links carefully!!!
Common issues
On every major upgrade it is recommended to do a full upgrade by deleting all files and folders within your installation directory except /data/ and /config/ and then extract the new code into this installation directory. How to do a full upgrade can be found at the documentation:
https://doc.owncloud.org/server/8.2/adm ... -procedure
Updates between multiple major versions and downgrades are unsupported.
Please see: viewtopic.php?f=17&t=32087
Known Bugs
A list of bugs to fix or features to include for 8.2.6 is available here: https://github.com/owncloud/core/milest ... aintenance
Massive increase in MySQL-load: https://github.com/owncloud/core/issues/24651
fix will be included in 8.2.6: https://github.com/owncloud/core/pull/24841
Files locked: "server replied: Locked" or "Exception: <filename> is locked"
-> Was fixed with 8.2.2
-> If this still happens with existing files a manual cleanup of the locking table is needed
--> See https://github.com/owncloud/core/issues/21360 for more details
Known Issues with PHP 7
You need at least oC 8.2.3 for full PHP 7 compatibility. With PHP 7.0.6 there is small issue that will be fixed in OC 8.2.4:
viewtopic.php?t=36312
until this new release, you can apply this patch manually: https://github.com/owncloud/core/pull/24344
When running Apache and PHP there is currently also an issue within the .htaccess shipped by oC. Make sure that you replace:
<IfModule mod_php5.c>
with
<IfModule mod_php7.c>
in your .htaccess. Ref: https://github.com/owncloud/core/issues/21146
Fixed Bugs
Shared folder (by link) doesn't display all files
-> Was partly fixed in 8.2.1 but happens again for two reasons:
--> PDF Viewer App might cause this
---> Report: https://github.com/owncloud/core/issues/21373
--> Internet Explorer (IE) still doesn't show all files
--->Report: https://github.com/owncloud/core/issues/21203
-> Fix for both issues is included in 8.2.3: https://github.com/owncloud/files_pdfviewer/pull/92
https://github.com/owncloud/core/pull/22548
E-Mail notifications not sent out
-> Might be caused by a deleted background job.
--> A possible workaround was posted here: https://github.com/owncloud/core/issues ... -166311215
--> The issue is also fixed with oC 8.2.3 and the update should re-add the background job automatically.
Updater is failing with "Unable to move /var/www/owncloud/_oc-upgrade/8.2.1.4/core/resources to /var/www/owncloud/resources
Workaround: https://github.com/owncloud/updater/pull/192/files
-> Was fixed with oC 8.2.2. If you have a oC version prior to 8.2.2 you need to manually apply the fix of the workaround above.
Unable to generate a URL for the named route "xyz" as such route does not exist.
Report: https://github.com/owncloud/core/issues/19145
Workaround: https://github.com/owncloud/core/pull/20788
-> Was fixed with oC 8.2.2 / 8.1.5
Cannot share at all when share with link is disabled globally
Report: https://github.com/owncloud/core/issues/20642
Workaround: Enable "Share by link" or apply https://github.com/owncloud/core/pull/21012 manually
overwritewebroot config setting is broken which is needed for SSL-Proxies
https://github.com/owncloud/core/issues/19901
-> Was fixed with oC 8.2.1
Base table or view not found: 1146 Table 'owncloud.file_locks' doesn't exist'
Workaround: https://github.com/owncloud/core/issues ... -151804321
Public / anonymous uploads via shared link stopped to work
https://github.com/owncloud/core/issues/19922
https://github.com/owncloud/core/issues/19886
Workaround: https://github.com/owncloud/core/commit ... e5ac919ed0
Performance issues since 8.2.0
https://github.com/owncloud/core/issues/19888
-> Was fixed with 8.2.1
-> Current Workaround: Use redis for transactional file locking (See documentation)
Google drive mounted folder expires after some days
https://github.com/owncloud/core/issues/15768
There are various incompatibilities with PHP7 known. Especially the shipped SabreDAV library 2.x in oC 8.2 is not compatible with PHP7. More resources:
https://github.com/owncloud/core/issues/21461 -> WebDAV issue
https://github.com/owncloud/core/issues/21309 -> Calendar/Contacts issue
https://github.com/owncloud/core/issues/21095 -> APCu issue (stripped page)
https://github.com/owncloud/core/issues/21352
https://github.com/owncloud/core/issues/21476
Until oC 9.0.0 or 8.2.3 is released which ships PHP7 compatible versions of SabreDAV it is recommended to stay at PHP 5.x.
*gone*
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: Upgrade to oC 8.2.x (known issues and faq)
Postby tflidd » Sat Nov 21, 2015 1:17 am
Please only post known issues here (must be confirmed on github).
DO NOT post your individual problem during the update/upgrade process. Open a separate topic for that.
marsden_pete
Beginner
ownCloud version: 8.1.5
Webserver: Apache
Re: ownCloud 8.2.x (known issues, faq and upgrade problems)
Postby marsden_pete » Tue Feb 23, 2016 1:54 pm
When upgrading to 8.2.2 you may get the error
Here is your backup: /var/derwentcloud/data/updater_backup/8.2.1.4-7d023030
Update failed.Unable to move /var/www/html/_oc-upgrade/8.2.2.2/core/resources to /var/www/html/resources
This is a known issue
viewtopic.php?f=36&t=31252 under “Fixed Bugs”
This is a user guide of how I resolved the issue; I am very new to Linux and OwnCloud so hopefully these steps will help people. I used SecureCRT to communicate with the server. All commands are in bold. Please take a backup of the server before running these steps.
I first had to locate the core.php file as mentioned in the bug fix.
https://github.com/owncloud/updater/pul ... diff=split
To do this I ran from the root directory
find –name “core.php”
from this I could see the file was located in
/var/www/html/apps/updater/lib/location/
Run the following commands
cd /var/www/html/apps/updater/lib/location/ - (change to the folder where core.php is located)
ls –l (list permissions on files)
sudo chmod 777 /var/www/html/apps/updater/lib/location/core.php - (changed the permissions to rwxrwxrwx)
nano core.php - (opens a text editor to edit the file)
change the line
$list = $fullList[‘8.1];
TO
$list = $fullList[‘8.2];
Overwrite the file and exit – I went back in to just double check the file had saved.
sudo chmod 644 /var/www/html/apps/updater/lib/location/core.php -(change the file permissions back to the previous permissions)
Run the upgrade from the OwnCloud Admin page.
Good Luck and i hope this helps and saves people a couple of hours
