how to force the use of HTTPS?
Please upgrade your ownCloud.
ovidiu
Beginner
Postby ovidiu » Sun Jul 08, 2012 11:39 pm
I tried editing the .htaccess file and inserted these lines right after
Code: Select all
RewriteEngine on
Code: Select all
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
since that resulted in a redirect loop (yes I emptied my browser cache)
I then tried this:
Code: Select all
RewriteRule ^.*$ https://%1/$1 [R=301,L]
but that also gave me a redirect loop.
Can someone please explain how to force OC to use HTTPS via .htaccess?
Environment: Debian 6.0.5
Server: own root server
Database: MySQL 5.1.63
Client: MAC Lion
OC-Version: 4.0.4
PHP-Version: 5.3.3-7+squeeze13
Richie
Beginner
Re: how to force the use of HTTPS?
Postby Richie » Mon Jul 09, 2012 3:41 am
Good day!
In my case, what I did was I edit the file which is ".htaccess" following the path "/var/www/html/owncloud/.htaccess" and inserted the lines:
after the line :
RewriteEngine on
Also, make sure you have something as follows in httpd.conf (mod_rewrite support):
LoadModule rewrite_module modules/mod_rewrite.so
I got this idea in http://www.cyberciti.biz/tips/howto-apache-force-https-secure-connections.html
You can check it out, but start in the topic "Force webmail login over SSL https session"
I hope that can help :D
ad2012
Beginner
Postby ad2012 » Mon Jul 09, 2012 9:24 am
For me, adding
Code: Select all
"forcessl" => true,
to my config.php did the trick :)
ovidiu
Beginner
Postby ovidiu » Mon Jul 09, 2012 9:34 am
Code: Select all
"forcessl" => true,
did the trick for me, thank you very much :-)
Client: MAC Lion
OC-Version: 4.0.4
ad2012
Beginner
Postby ad2012 » Mon Jul 09, 2012 9:37 am
ovidiu wrote:
Code: Select all
"forcessl" => true,
A better documentation would be great :)
But there is a sample config.php where to find a couple of nice settings!
Karaoko
Beginner
Postby Karaoko » Mon Jul 09, 2012 9:02 pm
where is the sample config.php ?
ovidiu
Beginner
Postby ovidiu » Mon Jul 09, 2012 9:47 pm
@Karaoko: its inside your config folder, named config.sample.php
@ad2012: thx for the hint. I had not looked into the sample config file because usually the sample is copied/renamed into the proper file and things are just commented, it had never occurred to me to think there was more stuff in the sample file than in the live config file :-)
Client: MAC Lion
OC-Version: 4.0.4
Users browsing this forum: Bing [Bot] and 0 guests
