Error 404, index.php not found
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
warden
ownCloud version: 9.0.0
Webserver: Apache
PHP version: 5.6.17
Postby warden » Tue Mar 08, 2016 11:53 pm
Environment: Devuan 64-bit Jessie, up to date
Server: Apache 2.4.x
Database: mysql, mariadb
Client: N/A
OC-Version: new 9.0
PHP-Version: 5.6.17
I just updated OC from 8.2 to 9.0 by way of an apt-get upgrade from apt. All went smooth until I tried to access the login page at "http://ip-address/owncloud" and I get an error about "index.php not found on this server". However, when I access the site from "http://ip-address/owncloud/index.php", it works as it should. Then when I logout it refreshes the page back to "http://ip-address/owncloud" where I get the same dreaded error page again.
What I have checked:
The root of OC is at /var/www/owncloud with an apache alias
The alias in the owncloud.conf is working okay, I guess... "Alias /owncloud "/var/www/owncloud/".
This was working fine in v.8.2.x, but the update altered it. Really the only thing different that I can spot might be the .htaccess file, but I can't spot what could be altering the index.php file.
Ideas?
dathbe
Beginner
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.4
Re: Error 404, index.php not found
Postby dathbe » Tue Mar 08, 2016 11:59 pm
Same issue here.
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Postby tflidd » Wed Mar 09, 2016 12:16 am
This error has been reported: https://github.com/owncloud/core/issues/22970
A temporary fix is to comment this line in /var/www/owncloud/.htaccess:
Code: Select all
RewriteRule .* index.php [PT,E=PATH_INFO:$1]
If someone can capture the traffic between browser and server, this would help to solve this issue:
https://github.com/owncloud/core/issues ... -193964395
dathbe
Beginner
Webserver: Apache
PHP version: 5.4
Postby dathbe » Wed Mar 09, 2016 12:36 am
If I knew how to capture the traffic, I would do so.
tflidd
Forum Moderator
Webserver: Apache
Postby tflidd » Wed Mar 09, 2016 12:50 am
kslagerman
Webserver: Apache
PHP version: 5.6.11
Postby kslagerman » Wed Mar 09, 2016 8:03 am
Same here. Upgraded to 9 via Ubuntu package manager. Everything went fairly smooth but I immediately noticed that I now need to enter the full URL to access ownCloud. e.g. "...<myserver>/owncloud/index.php"
I took a look at the .htaccess file in the /owncloud/ dir and the DirectoryIndex index.php line appears to be correct.
Minimal inconvenience, but it would be nice to know what happened.
dathbe
Beginner
Webserver: Apache
PHP version: 5.4
Postby dathbe » Thu Mar 10, 2016 1:15 am
I can confirm that the fix at GitHub https://github.com/owncloud/core/pull/23029 works with two caveats:
1) changing only .htaccess (leaving setup.php alone) seems to do the trick. I can't determine what the change to setup.php does.
2) the url now seems to include index.html everywhere; e.g., https://host.com/owncloud/index.php/apps/files/ . So the site works, but the url is still a little wonky.
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Thu Mar 10, 2016 1:22 am
Please keep the discussion about this issue at the linked issue.
*gone*
Return to “ownCloud Server 9.0”
