[SOLVED] dev/urandom is not readable by PHP on Synology
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
own315
Beginner
ownCloud version: 9.0.0
Webserver: Apache
OS: Linux Embedded
PHP version: 5.5.31
Postby own315 » Sat Mar 12, 2016 4:25 pm
Environment: Synology NAS 412+/Linux 3.10.35
Server: Apache/2.2.31 (Unix)
Database: MySQL/MariaDB 5.5.44-0034
Client: Firefox on Windows 7/CardDAV on iOS 9.2.1
OC-Version: 9.0.0.19
PHP-Version: 5.5.31
Hello, after upgrade to 9.0.0, I get the warning in the admin pane:
Code: Select all
dev/urandom is not readable by PHP which is highly discouraged for security reasons.
I tried to add this line to the config.php, but the message is still there:
Code: Select all
'memcache.local' => '\OC\Memcache\APCu'
Error Logs:
Code: Select all
is_readable(): open_basedir restriction in effect. File(/dev/urandom) is not within the allowed path(s): (/var/services/tmp:/etc.defaults:/usr/bin/php:/usr/syno/synoman:/etc:/var/run:/volume1/@tmp/php:/var/services/web:/var/services/photo:/var/services/blog:/var/services/homes) at /volume1/web/owncloud/3rdparty/paragonie/random_compat/lib/random.php#66
Thanks a lot!
PHP-Version: 5.5.31
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: dev/urandom is not readable by PHP
Postby RealRancor » Sat Mar 12, 2016 4:30 pm
Please put the message:
into your favorite search engine how to correctly configure this PHP setting. Even the already linked:
https://doc.owncloud.org/server/9.0/adm ... ndom-label
in your previous topic is giving you the info what to do:
When having an open_basedir configured within your php.ini file, make sure to include /dev/urandom.
*gone*
hoorna
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.26
Postby hoorna » Sat Mar 12, 2016 5:02 pm
@own315: You can edit the open_basedir definition in the DSM 5.2 webinterface at Configuration Settings -> Webservices -> PHP-settings. Add at the end of the line ":/dev/urandom".
own315
Beginner
Webserver: Apache
OS: Linux Embedded
PHP version: 5.5.31
Postby own315 » Sun Mar 13, 2016 2:02 am
hoorna wrote:Add at the end of the line ":/dev/urandom".
Hey hoorna, that was it! Great, thanks!
PHP-Version: 5.5.31
Return to “ownCloud Server 9.0”
