PHP Fatal error: Call to a member function getUID() on a non-object in apps/dav/appinfo/app.php on line 49
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
heinz
ownCloud version: 9.0.0
Webserver: Apache
PHP version: 5.5.9
Postby heinz » Fri Mar 25, 2016 1:25 pm
Hi, i have a problem with the mail-report regarding the activities.
Can anybody help me?
regards,
heinz
1. Enable user_ldap
2. In Personal settings - Activity: activate "MAIL: A file or folder has been changed"
3. share a folder
4. upload a file in the shared folder
5. launch: php -f cron.php
The system should send a report regarding the activities.
I get a error:
PHP Fatal error: Call to a member function getUID() on a non-object in /owncloud/prog/test/apps/dav/appinfo/app.php on line 49
Operating system: Linux Ubuntu 14.04.4 LTS
Web server: apache2
Database: mySQL
PHP version: 5.5.9
ownCloud version (see ownCloud admin page): 9.0.0 (stable)
Updated from an older ownCloud or fresh install: updated from oc8
{"reqId":"6Rk5YFRwjarH6rL16SeV","remoteAddr":"","app":"PHP","message":"Call to a member function getUID() on a non-object at \/owncloud\/prog\/test\/apps\/dav\/appinfo\/app.php#49","level":3,"time":"2016-03-25T11:26:08+00:00"}
Enabled:
- activity: 2.2.1
- comments: 0.2
- dav: 0.1.5
- documents: 0.12.0
- federatedfilesharing: 0.1.0
- federation: 0.0.4
- files: 1.4.4
- files_external: 0.5.2
- files_sharing: 0.9.1
- files_texteditor: 2.1
- files_trashbin: 0.8.0
- files_versions: 1.2.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 14.5.0
- notifications: 0.2.3
- provisioning_api: 0.4.1
- systemtags: 0.2
- templateeditor: 0.1
- updatenotification: 0.1.0
- user_ldap: 0.8.0
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Re: PHP Fatal error: Call to a member function getUID() on a non-object in apps/dav/appinfo/app.php on line 49
Postby RealRancor » Fri Mar 25, 2016 1:31 pm
please always report such "Fatal errors" directly to the developers at the bugtracker:
viewtopic.php?f=32&t=23696
viewtopic.php?f=17&t=20688
*gone*
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Fri Mar 25, 2016 2:58 pm
Ref: https://github.com/owncloud/core/issues/23581
Seems some one reported it a few minutes ago.
*gone*
Return to “ownCloud Server 9.0”
