gitHub #13426 - OC9.0.2 - Users in multiple ldap groups only show up in one group
Ask all your questions regarding OC 9.0 Please read the Support Forum Rules
clvstle
ownCloud version: 8.1.1
Webserver: nginx
PHP version: 5.6.6
Postby clvstle » Thu Jun 02, 2016 7:05 am
1. Created 3 groups in Server 2012R2 AD [GROUP 1, GROUP 2, GROUP 3]
2. Added 5 same users to all groups
3. Set OC LDAP to search for group (it finds the groups and all 180 of my users - including users that are in the groups)
4. Go to OC > Admin > Users > and view GROUP 1, GROUP 2, GROUP 3
I should be seeing the 5 users in each group
I see 5 users in GROUP 1, but not in GROUP 2 or GROUP 3. If I remove 2 users, I see the 2 removed users in GROUP 2 or GROUP 3 and the other 3 stays in GROUP 1
Operating system: Linux Debian 8.5 - Jessie
Web server: NGINX 1.6.2
Database: MySQL 5.5.49-0+deb8u1
PHP version: 5.6.20-0+deb8u1
ownCloud version (see ownCloud admin page): 9.0.2
Updated from an older ownCloud or fresh install: updated from older version 8.2.2
Code: Select all
Debug   user_ldap   Ready for a paged search   2016-06-02T00:00:22-05:00
Debug   user_ldap   initializing paged search for Filter (&(|(objectclass=group))) base Array ( [0] => cn=GROUP 1,ou=owncloud server,ou=owncloud group,dc=domain,dc=com ) attr Array ( [0] => member ) limit 500 offset 0      2016-06-02T00:00:22-05:00
Error   PHP   ldap_control_paged_result_response(): Result is: No such object (32) at /var/www/owncloud/apps/user_ldap/lib/ldap.php#70   2016-06-02T00:00:22-05:00
Debug   user_ldap   initializing paged search for Filter objectclass=* base Array ( [0] => DC=domain,dc=com ) attr Array ( [0] => dn ) limit 500 offset 500   2016-06-02T00:00:29-05:00
Debug   user_ldap   Ready for a paged search   2016-06-02T00:00:29-05:00
Debug   user_ldap   initializing paged search for Filter objectclass=* base Array ( [0] => DC=domain,dc=com ) attr Array ( [0] => dn ) limit 500 offset 0   2016-06-02T00:00:29-05:00
Debug   user_ldap   Count filter: objectclass=*   2016-06-02T00:00:29-05:00
Debug   user_ldap   No DN found for GROUP 1(group) on dc.domain.com   2016-06-02T00:00:29-05:00
Debug   user_ldap   No DN found for GROUP 2(group) on dc.domain.com   2016-06-02T00:00:29-05:00
Debug   user_ldap   No DN found for GROUP 3(group) on dc.domain.com   2016-06-02T00:00:29-05:00
Debug   user_ldap   No DN found for files_external on dc.domain.com
3x External Storage - SMB/CIFS - GROUP 1 has access to an external storage, GROUP 2 has access to another external storage, GROUP 3 has access to the third external storage.
Whichever GROUP has the user, those users can see the External Storage just fine.
-------update 1
It seems this is an existing issue and @ichigami also mentioned he/she patched it - but i'm not seeing a patch
https://github.com/owncloud/core/issues/13426
------update 2
My fault, the solution was posted at the beginning of the github thread. In version 9.0.2 - the location of group_ldap.php was located in owncloud/apps/user_ldap/group_ldap.php - adding the 500 fixed the issue. I had to clear the existing cache and re-populate the permissions.
This would be awesome if it would be implemented in future updates!
Thanks @PeteSSS for posting the work-around for the time being!
tflidd
Forum Moderator
ownCloud version: 8.2.3
Webserver: Apache
Re: gitHub #13426 - OC9.0.2 - Users in multiple ldap groups only show up in one group
Postby tflidd » Fri Jun 03, 2016 10:47 am
Please push your feedback to github. The developers don't read in here.
Return to “ownCloud Server 9.0”
