Google account sync
You found a bug or you're missing a major feature? Just ask and discuss
VicDeo
Developer
Google account sync
Postby VicDeo » Tue Jan 24, 2012 2:41 am
App is available here.
Contacts import is implemented at the moment.
owncloud 4.5.x http://apps.owncloud.com/content/show.p ... ent=151488
owncloud 4.x
gsync-0.4.tar.gz
ownCloud 4.x
(140.22 KiB) Downloaded 315 times
ownCloud 3.x https://gitorious.org/owncloud/owncloud ... v0.2/gsync
v0.2.tgz
ownCloud 3.x
(34.76 KiB) Downloaded 240 times
FAQ:
Some contacts are imported as UNKNOWN
Check 'Other contacts' in your Google contacts. You will see a number of contacts that have no other data specified except email. All those contacts are imported as UNKNOWN.
TODO:
Code: Select all
* test it a bit ;)
Changelog:
Code: Select all
v0.4.1
* tested with 4.5
* Fixed incorrect names order for 4.5
* Fixed reversed ZIP/Country order for 4.5
* Email types support
v0.4
* Note property support
* More stable and faster
* Group caching to reduce the number of requests
* Skip contacts changed in ownCloud within last 10 minutes
* Autosync support *Experimental*
* Logic moved to PHP model
v0.3.2
* Do not store contact image if the format is not recognized
* Rescan contact groups
v0.3.1
* fixed name collision with the app title at apps.owncloud.com
* sanitize input for Client ID
* check for the php-curl extension
* cUrl SSL error fix
v0.3
* ownCloud 4 compatibility
* Birthday property support
* Nickname property support
* Groups support
v0.2
* OAuth 2.0
* Gdata library dismissed / Manual data parsing
* Sync for previously imported contacts
* Photo export
v0.1.2
* Minor bugfixes
v0.1.1
* Compatibility: The 'N' VCard property is taken according to the current dev version of owncloud
* Bugfix: Infinite request permissions loop
* Required ownCloud version changed to 3
v0.1
* Implemented Google contacts import
Last updated on: Feb 26, 2013
no sorry for myself
tpn
Developer
Re: Project participation
Postby tpn » Tue Jan 24, 2012 4:43 pm
Come hang out in the irc channel sometime (unless you already do :) )
#owncloud on freenode
VicDeo
Developer
Re: Google account sync
Postby VicDeo » Mon Jan 30, 2012 10:47 pm
Well, I have taken the challenge :)
I'm not sure whether it was a good idea to clone the whole 'apps' repository. :roll:
https://gitorious.org/~vicdeo/owncloud/ ... ster/gsync
For now it adds the 'Import Contacts' button to the personal page to pull all the contacts from the Google Contacts into the newly created address book.
The feedback is appreciated as I need to be sure that I'm on a right track
no sorry for myself
VicDeo
Developer
Postby VicDeo » Thu Feb 02, 2012 8:34 pm
Did anybody try it?
I really need some feedback for further work
no sorry for myself
ricardopvz
Postby ricardopvz » Thu Feb 02, 2012 8:54 pm
VicDeo wrote:Did anybody try it?
I tried it but it keeps redirecting to google account to grant access
potex
Postby potex » Thu Feb 02, 2012 9:09 pm
have tried it today and dont work.
Same as "ricardopvz", it redirects to google and if i accept it refresh and again to google, i have done this 5 times and always redirect to google accept page
Would be great if you can fix this.
Greets
VicDeo
Developer
Postby VicDeo » Thu Feb 02, 2012 10:31 pm
Thanks for feedback :D
Hmm.. Browsers are too fast and execute a new login request while setting the cookie got from the previous one.
I've commited a workaround for that. Please check if it works now.
no sorry for myself
ricardopvz
Postby ricardopvz » Thu Feb 02, 2012 10:44 pm
VicDeo wrote:Thanks for feedback :D
It works now, but there's another problem.
After import, in contacts this is what i get in every contact:
ricardopvz
Postby ricardopvz » Thu Feb 02, 2012 10:54 pm
Found the problem.
The card data is missin the "N:" thing
VicDeo
Developer
Postby VicDeo » Thu Feb 02, 2012 10:55 pm
ricardopvz wrote:It works now, but there's another problem.
AFAIK the 'N' vcard property is not implemented in the stable release. You have the recent version from the repo, don't you?
no sorry for myself
Return to “Discuss possible bugs & feature requests”
