How to change upload limits and fix upload problems
Here we try to answer typical questions
User avatar
RandolphCarter
ownCloud master
ownCloud version: 8.1.1
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Thu Jan 17, 2013 2:42 pm
The first starting point containing infos how to deal with big file uploads is the official documentation available here:
https://doc.owncloud.org/server/8.2/adm ... ation.html
If you can't find the needed infos there continue with this informations:
If you have problems uploading files in general:
If you have problems uploading files over a certain size limit, make sure
The maximum allowed upload size is determined as the minimum of these values:
  • php configuration entry "post_max_size"
  • php configuration entry "upload_max_filesize"
  • The free space left on the target device
Important notes:
  • The post_max_size and upload_max_filesize in your php.ini gets overwritten by the .htaccess file shipped with ownCloud when AllowOverride is set to All. If you're using the default .htaccess file shipped by OC you will see an upload limit of 513MB.
  • If your upload_tmp_dir directive of your php.ini is located on a different partition also make sure that this folder has enough space for uploading large files.
For the php values, you should make sure the values you are setting are actually considered (see "How to check your PHP version and configuration"; when calling the info.php file in the browser, you should see the configuration values from above on the output, with the values as php is using them at the moment. If they don't reflect what you have set, one of the most common problems is that you didn't restart the server after changing them.
Another probably cause on apache servers if you set the values via .htaccess would be that the "AllowOverride" directive in your virtual host is set to "None", and therefore no .htaccess settings are considered; change it to "All".
Setting the maximum upload size in the Webinterface
In most installations, there is a maximum upload size to be configured in the "Admin" section as administrative user called "File handling". This sets the two above php settings in the .htaccess file. If you don't see this option, your .htaccess is not writable, or it isn't effective!
Users running NginX, lighttpd or other webservers not using .htaccess files won't see the gui too.
Note for windows/IIS users: You should take a good look at this tutorial: viewtopic.php?f=8&t=2370 (especially the "Request Filtering" section)
Note for really big files (>2GB): If your upload fails with a message like "Upload exceeds your max_upload_limit", you might consider updating your php to a newer version. For me, this problem occured with files > 2GB with php version 5.3.10, but was solved with version 5.4.13.
Bugreport at the php bugtracker for this issue: https://bugs.php.net/bug.php?id=60205
Reason: Fix link to official docs
openworld
Re: How to configure upload limits
Postby openworld » Sat Feb 16, 2013 3:24 pm
I had problems uploading files in general and this post didn't help (It took me a long time to understand it (it links to German...) and it was a dead-end.
In my case, this link gave the solution : viewtopic.php?f=3&t=1878
If you want to know if you are in a similar situation, check this parameter (via info.php containing phpinfo()) : disk_free_space. If it is disabled and you cannot change it (your providers)... then this might be the solution.
The first step was to check some settings because I use a commercial shared hosting : post_max_size, upload_max_filesize, max_file_uploads. The default values of my provider weren't bad, so it was not the problem. It is easy to check if you put an info.php file (with phpinfo() in it).
At first, application said max upload size is 0. I managed to get beyond that without solving the problem and then the application said "no more space left on device"... which I knew was not true. In fact, owncloud uses "disk_free_space" in order to check free space on the disk but many providers block this function. If "disk_free_space" is deactivated, it makes it impossible to use file uploads... So this was the root cause in my case.
The solution is explained in the link mentioned earlier. You have to comment some lines here : ./3rdparty/Sabre/DAV/FS/Directory.php and put a value here : ./lib/filestorage/local.php
RealRancor
ownCloud master
ownCloud version: 9.0.2
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Wed Feb 20, 2013 10:58 am
RandolphCarter wrote:In most installations, there is a maximum upload size to be configured in the "Admin" section as administrative user. This sets the two above php settings in the .htaccess file. If you don't see this option, your .htaccess is not writable, or it isn't effective!
Additionally NginX users have to set this:
Code: Select all
fastcgi_param htaccessWorking true;
in the
Code: Select all
location ~ \.php$
block and restart NginX. I've just reported a bug at the documentation bugtracker so this will be added to the NginX configuration example.
*gone*
jonhenry
ownCloud version: 4.5.7
Webserver: Apache
OS: Unknown
Postby jonhenry » Tue Feb 26, 2013 6:16 pm
openworld wrote:In my case, this link gave the solution : viewtopic.php?f=3&t=1878
Hey open, thanks for the walkthrough, I didn't get the above either so hopefully the link you gave and your instructions will help, ty ty
Henry
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Re: How to change upload limits and fix upload problems
Postby RealRancor » Wed Apr 03, 2013 4:57 pm
There is also a document about "Common Pitfalls" when uploading files via PHP (what OC is doing) available here:
http://www.php.net/manual/en/features.f ... tfalls.php
*gone*
Budgreg
Beginner
Postby Budgreg » Thu Apr 18, 2013 11:15 pm
After months of troubleshooting this post solved my sync issues: http://www.joh.fi/blog/2013/01/11/installing-owncloud-on-a-shared-host/
In short:
=> Edit the .htaccess file in your OwnCloud Folder
=> In the <IfModule mod_rewrite.c> section change the following line
Code: Select all
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}
to
Code: Select all
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
(just add ",L" at the end)
=> Add the following lines to the end (after the last section):
Code: Select all
Order allow,deny
Allow from all
br, Gregor
tsukaeru
ownCloud version: 5.0.6
Webserver: nginx
PHP version: 5.4.15
Postby tsukaeru » Tue Jun 11, 2013 8:58 am
RandolphCarter wrote:If you have problems uploading files in general:
I have 5.4.15, but still see the same problem with anything > 2047M. I am using the x64 remi RPMs. Did you compile PHP yourself?
RealRancor
ownCloud master
Webserver: nginx
PHP version: 7.0.x
Postby RealRancor » Tue Jun 11, 2013 10:08 am
as you can see at the two other linked bug reports above this is still an issue with 32 and 64bit systems. Probably the distro of RandolfCarter has included this custom patches and the RPMs of remi not.
*gone*
User avatar
RandolphCarter
ownCloud master
Webserver: Apache
PHP version: 5.5.x
Postby RandolphCarter » Fri Jul 05, 2013 1:57 pm
I haven't built php myself; I use the 5.4.13 package (5.4.13-2~precise+1, to be exact), from a custom ppa: http://ppa.launchpad.net/ondrej/php5/ubuntu , as recommended e.g. here: http://askubuntu.com/questions/109404/h ... n-ubuntu-1
Probably they've included some patches regarding this.
If I have time I will test whether this is fixed in the official php5.4 package on latest 13.04 version.
axxo1
Postby axxo1 » Sun Aug 25, 2013 8:01 am
Do you know if is it possible to set upload_max_filesize in an .htaccess file?
I have been trying it without success, but it might be just me.
Return to “FAQ”
Users browsing this forum: No registered users and 4 guests
